Nov 02, 2018, 10:56 AM
Originally Posted by scruffy1
that motor is fantastic ! i use it on my jupiter shrimp, but equip it with a 6x3 because of space constraints for the prop, and use a 3s 460mah lipo
https://www.rcgroups.com/forums/show...d#post39845079
trial with 7x4 on 3s fails as the o-ring is inadequate to hold the prop at full power, and there's no provision for a prop nut
draws 7.22amp peak on 3s, for 80 watts of power
the shrimp is 26" (600mm) and ~ 220gm all up with battery
more than ample power and gives ~ 8 minutes air time flying "nicely" - can go vertical with full revs
the baby at 33" would do well, but you'll benefit from increasing the nose moment as the weight of this motor is not enough to get the cg well placed, and you can't add a spinner for ballast like i did on my baby
I would like to make massive wing with this electronics that I mentioned. Would it be all right?
Nov 02, 2018, 10:59 AM
I actually wanted to use this electronics to make a mini Ugly Stick, but I found it very laborious to make those cuts on the lego in hand. I wanted to make an airplane easy-to-build coach. That's why I thought Blu Bbby
Nov 02, 2018, 08:51 PM
looking up, down under
scruffy1's Avatar
depending on your flying skills and what you are aiming to do with the plane, maybe you should have a look at the "trottel"
https://www.rcgroups.com/forums/show...hine-free-plan
that motor would be ideal for it
Nov 02, 2018, 10:45 PM
I'm a beginner, I do not think I'll be able to fly the aero that you mentioned.
Nov 03, 2018, 06:08 AM
scruffy1's Avatar
the baby is a much safer bet
although in truth, the kf2 airfoil is simpler than bending an undercamber
Nov 03, 2018, 10:37 AM
is electronics would not look better on 24 instead of 33 ...?
Turnigy A2204 14T
Micro Servos 9g
Esc 15a
Lipo 2s 1000mah (67g)
Nov 03, 2018, 10:55 AM
Motor Turnigy A2204 14T 19g
2x Micro Servos 18g
Esc 15A HobbyKing Speedo Control 15g
Lipo 2S 1000 Zippy Compact 1000mah 67g
Receptor Turnigy 5CH 6,5g
Total 125,5g
Nov 03, 2018, 02:24 PM
justj's Avatar
With that motor:
2 x 4.3g or 5 g servo [8.6 to 10 g]
2S 800mah [15 min flight times]
10A ESC
3 ch receiver
33" WS
I've built and flown 20+ 33" and 40" WS Versions
Jerry
Nov 03, 2018, 07:50 PM
My Blu-Baby 24 maiden
Hi all
This morning maiden my 24" Blu-Baby
Turnigy D1306 4000kv
2S 750ma lipo
2x 5g servos
Emax blheli 12a ESC
2 ch receiver mini
AUW 165 grams ( ready to fly )
I built it without the Monobloc just with sides and formers. not sure how it is supposed to perform but it flies nice and steady quite slow on about half throttle but given full throttle and pointed up just goes ballistic. I don't think it is designed to do that as I did a loop and coming out the wings clapped the tips together. The only thing that could of saved it would have been full reverse thrust. When I walked over to pick it up the wings were ok and the prop was ok so just checked movements straightened the wing and kept flying, but of course the wings folded again when going to fast. So will give it a carbon spare to fix the clapping wings. May give it some ailerons, as I just love the way it flies but hate the dutch roll no good for low flying.
Tony
Nov 04, 2018, 12:21 AM
Jim
Originally Posted by TIMBOLOGIST
Hi all
2S 750ma lipo
2x 5g servos
Emax blheli 12a ESC
2 ch receiver mini
Tony
If the wing has the clap you'll need to burn that wing and build a new wing! Full reverse thrust wouldn't have helped either
Nov 08, 2018, 08:56 AM
Build, crash...repeat
AleRRon's Avatar
Ballistic
Tony
You mentioned your plane “went ballistic” when pointed up. Do you mean the nose pitched up severely and sort of out of control? Or something different? Many planes do that when throttle is increased, and fly better and stop doing that if some downthrust angle is given to the motor.
Bob
Nov 08, 2018, 09:36 PM
Ken's CAD Models
dz1sfb's Avatar
Ballistic - adjective - denoting or relating to the flight of projectiles.
Ken
Latest blog entry: Mini H Quad Project
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 07:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 12:50 PM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 10:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 08:38 PM
