Sep 09, 2011, 12:55 AM
Remember... Fly for fun!
ALEX HEWSON's Avatar
Here is my proposed solution. one sticking almost straight up to catch signal from above and behind
Sep 09, 2011, 02:11 AM
Fly DLG
Alex,
Check this thread that I started to try and collect information on various carbon/partial carbon installations that have been successful.
https://www.rcgroups.com/forums/show....php?t=1501980
Sep 09, 2011, 05:22 AM
Awesome thanks for the link, Mike!
Sep 09, 2011, 12:56 PM
Hit my smoke....
Hostage-46's Avatar
Do you have range problems in low power mode? Or is it more of a concern? Direct line of site does not necessarly apply. Shielding may not be obvious based on visual presentation.
Sep 09, 2011, 06:40 PM
Only in low power mode. Release the button and control resumes. Didn't test range on full power to test for holds
Sep 09, 2011, 10:14 PM
Hit my smoke....
Hostage-46's Avatar
you need control at all orientations in low power mode from the prescribed distance for your radio, typically 30 paces or so.
Better to move a few antennas around on the ground than the alternative
Sep 09, 2011, 11:20 PM
I haven't tested with my new aerial placement. Will do it this afternoon
Sep 11, 2011, 05:07 AM
All good everyone, it works:
K100 AUSTRALAISIAN RECORD!!!!!! 11 Sept 2011 (10 min 28 sec)
Jul 03, 2013, 08:57 AM
I use 36 meg and guess what ? it works, and I run my antenna inside the fuse!
Jul 03, 2013, 09:08 AM
tkallev's Avatar
Originally Posted by telly
i use 36 meg and guess what ? It works, and i run my antenna inside the fuse!
lol
Jul 03, 2013, 11:32 AM
Proud member of LISF and ESL
Frequency conflict should be an ever decreasing issue, but then the discipline of frequency control has all but been lost. In some respects the non-2.4 guys may be more at risk than ever as people who switch back and forth forget to follow good frequency control practices.
Discussion Spektrum RX range tests (6000, 6100, 7000) Wind Junkie Radios 56 Feb 06, 2015 10:56 PM
Question Does a better radio make a stronger signal?/Range check problem birdlives1955 Radios 10 Aug 04, 2007 09:08 PM
Question How much range in an RX? SJC Beginner Training Area (Aircraft-Electric) 2 Jan 11, 2007 12:56 AM
Question how to build in an endgrain/carbon spar mlcleary Slope 2 Feb 21, 2005 04:58 PM
Rx Antenna routing on an F5B fuselage avalanche Electric Sailplanes 3 Apr 22, 2001 11:50 PM
