This thread is privately moderated by burkefj, who may elect to delete unwanted replies.
Mar 15, 2007, 01:09 PM
burkefj's Avatar
Alpha F-86
Just finished my Alpha F-86, Instead of getting the clear plastic covers for the inlet, I decided to try using gorilla glue to fill the front of the fuselage inlet to stiffen it. It worked quite well, however being the first time I used it, I used too much and had to scrape as it expanded, I did wind up having to trim about 1/8" of the front of the fuse foam to allow it to seat back all the way into the plane, but it is pretty stiff now I did use a roll of Photo paper with some silver mylar around it to extend the std duct to exit the rear of the
plane and smooth the exit a bit.
I've set it up with the mp jet motor, and TP1320 pack, AUW is 15.9 oz.
We'll see if it flies as well as my Mig.
Frank
Mar 15, 2007, 01:15 PM
willhaney's Avatar
Looking good.
Best of luck on the maiden.
Will
Mar 16, 2007, 05:29 PM
sailplate's Avatar
Nice F-86!
Hi I'm building an F-86 too. It's from Fan-tastic Models and a foamy. I'm almost finished with it. I used Gorilla glue instead of the epoxy and it worked well but it does expand. It takes a while to set but after 4 hours it's fully cured and amazingly it's water proof. The Gorilla glue label said it would work on foam and it was right. Good Flying!
Mar 16, 2007, 06:45 PM
burkefj's Avatar
Thanks for the comments, looks like they stopped producing the F-86, I was seriously looking at getting the Panther, as I've always like Bridges at toko Ri, I've got a bunch of the cox warbirds, and this would go well with them.
Frank
Help! Manual for Alpha F-86 Pokke Electric Ducted Fan Jet Talk 5 Nov 14, 2006 05:20 PM
Discussion Drop Tanks for Alpha F-86 davis akro Electric Ducted Fan Jet Talk 30 Jun 14, 2006 02:12 PM
Discussion How Do you post video? -Alpha F-86 MattZC Electric Ducted Fan Jet Talk 1 Mar 18, 2006 05:25 PM
Wanted Alpha F-86 Sabre EDF or close Riot-Pilot~ Aircraft - Electric - Airplanes (FS/W) 0 Nov 28, 2005 10:37 PM
