Is dihedral on a delta wing bad?
Hi all,
Im just glued a wing to a eurofighter, the instructions state the bottom surface should be level, but ive managed to put about 2 degrees dihedral onto the wing. How bad news is this? Not that i can do anything about it now anyway. ( Its a PJP eurofighter 60" lenght , 40" wingspan) |
I'm inclined to agree with V1 here, especially as the instructions are, in effect, telling you to put anhedral into the wing. I made a delta slope soarer which accidentally had a bit of dihedral, in order to prevent dutch roll, I chopped the tips and stuck them back on with anhedral to make a gull wing delta.
Which was a pile of crap ![]() Suck it and see though, but if you can see a way to undo it, then it will probably be worth the effort. Cheers |
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| Question | Differential Needed on Delta Wing Elevons? | FoamCrusher | Electric Plane Talk | 3 | Nov 20, 2004 11:30 PM |
| LED configuration for night flying on Delta wing? | rocstar | Foamies (Kits) | 7 | Oct 21, 2004 11:09 AM | |
| TE lifting in center on delta wing design. | Steve-S63 | Foamies (Kits) | 5 | Aug 07, 2004 12:09 PM | |
| Negative Dihedral on Flying Wing | wayne | Modeling Science | 8 | Nov 21, 2002 04:37 AM | |
| How to estimate CG on a Delta wing | leftysdeceiver | Electric Plane Talk | 4 | Oct 07, 2001 08:10 AM | |
