Feb 25, 2007, 09:45 PM
Mayday!
Newtron's Avatar
Ford (Stout) 2-AT finished... need 3-view of Ford Flivver
Here's my finished and flown Ford 2-AT.
WS = 46"
Length = 37.5"
AUW = 22 oz
It's a foamy, scaled up from the FF plans by Stu Weckerly.
Radio problems caused a crash on the maiden and the pictures are after the repairs.
The in-flight pics are taken from a choppy video of the crash.
https://www.rcgroups.com/forums/showthread.php?t=646412
Since repaired I've flown it 3 times and its a floater (FF origins?) but can really roll. It's especially cool seeing the large F-O-R-D on the wing's underside when it's in the air.
The rubber bands are temporary
While researching the 2-AT, I came across the Ford Flivver and want to model it but can't find a 3-view of it. Help please?
Tim
Feb 25, 2007, 10:03 PM
P. Tritle's Avatar
Tim, The 2-AT looks great! It's sure not one you see modeled often. Excellant job.
Williams brothers did a Ford Flivver -- 1/48 scale I think, and as always, their plans had really nice 3 view drawings for decal placement which would be well suited to your project. I don't have a kit here, but I'd bet theres someone out there somewhere who would be willing to scan the plans for you.
PAT
Feb 26, 2007, 02:04 PM
Tim, I hope you can use these three views.
Feb 26, 2007, 11:31 PM
Mayday!
Newtron's Avatar
Pat, thanks for the kind words. It's astonishing watching you produce the number of cool models you have. At your present rate, you may run out of worthy subjects .
Laddie, also thanks, that's exactly what I was looking for. I've been following your facetmobile build and can't wait to see the maiden video, hopefully the snow will melt soon.
Do either of you have any thoughts on whether I should enlarge the tail area on the flivver? Since I was working from a FF print on the 2-AT I was confident that the tail was large enough.
Tim
May 11, 2007, 09:17 AM
Mayday!
Newtron's Avatar
Update -all the issues have been worked out and 2-AT is an excellent flyer. Here's some video. Unfortunately I was the only one there so I had to set the camcorder down, point it toward the sky and hope for the best (ala alby and griffin et al).
https://www.rcgroups.com/forums/showthread.php?t=684463
Tim
May 12, 2007, 04:22 PM
Hi Tim
Dereck Woodward built a 1/5th scale version of the Flivver. The span is slightly over 50" and the tailplane span is about 14". From the three view, the relative sizes look to be about the same ratio. I must admit the tailplane does look small but I assume he built it to scale size. His write up states this a/c flew ok. I hope so as I am in the process of building this plane and hope to fly it soon. It will however have a four stroke up front, as I decided to have a change from electric power for a while. Best of luck with yours.
John
Jul 02, 2007, 08:44 PM
kdahlhaus's Avatar
2-AT Video
Uploaded a video of the 2-AT from this weekend:
https://www.rcgroups.com/forums/show...71#post7731769
Video Ford (Stout) 2-AT kdahlhaus Electric Plane Talk 1 Nov 07, 2010 08:23 PM
NEED 3-VIEW FOR POND RACER N221BP joe Electric Plane Talk 18 Jun 22, 2008 04:55 AM
Video Ford (Stout) 2-AT Newtron Electric Plane Talk 0 May 11, 2007 09:16 AM
Need 3-view of F4-U please 701 Super Jet Scale Kit/Scratch Built 3 May 16, 2002 01:04 AM
Need 3-View for Comet Taylorcraft E-Challenged Scale Kit/Scratch Built 5 Feb 07, 2002 07:23 AM
