Oct 05, 2002, 12:23 PM
Photo 4 shows the retracts that I use in the A-4. I can't find them anymore, shame. Oh the nose gear does not have steering, although I have already figured out how to modify them. These and other similar gears can be easily modified to make them rotate 90 degress so the wheels will lie flat inside the wing when retracted, I didn't do it here due to the weight constraints. I'll be happy to share my findings if anyone is interested.
Oct 05, 2002, 01:50 PM
Col.Hooligan Air Force
uncljoe's Avatar
battery source
Wilerbee
I purchased the 1700 thru DMA a Vendor here on E-Zone, The 1700's cps will result in shorter flights , But at a half a pound less will turn it into a fast plane ... Also I removed the rudder servo since I noticed no adverse yawing , Flies great at the CG & control settings suggested by Jean Paul
Enjoy the Scooter
Semper Fi
Joe
Oct 05, 2002, 07:28 PM
Uncle Joe,
Did you use zapped cells in your Jepe ? By the way, thanks for the tip on getting my cells. Also, the c.g. measurement in the instruction, did you take the measurement at the centre of the wing or at the wing root ?
Oct 05, 2002, 08:47 PM
Purple power
gregg f's Avatar
Originally posted by wilerbee
Uncle Joe,
their zapped, cg measured from the center..........gregg
Oct 05, 2002, 08:51 PM
uncljoe's Avatar
I did order the zapped cells, had the pack 10 cells per stick x2 =20 cells big bucks but worth it cg was 165mm
Semper fi
Joe
Oct 06, 2002, 06:21 AM
Thanks uncle Joe and Gregg. You guys are ace !!
Oct 23, 2002, 10:59 AM
The final touches on my Jepe A-4. The Road runner art and the name of the pilot is from a website I found. I also ordered some Li-polymer batteries to try out. Lets you guys know how it works out.
Oct 23, 2002, 11:00 AM
photo 1
Oct 23, 2002, 11:01 AM
photo 2
Oct 23, 2002, 12:05 PM
Lithium Member
Herb's Avatar
Wallet zapping vs LiPo suction
Very nice detailing. How did it fly with the LiPo cells, did you get as much power as with the NiCd's ? Perhaps you can post a video here of one of your flights.
"Unfortunately, the dry lithium-polymer suffers from poor conductivity. The internal resistance is too high and cannot deliver the current bursts needed for modern communication devices ...",
in "The Lithium-Polymer Battery: Substance or Hype?"
http://powerpulse.net/powerpulse/arc...a_080601a1.stm
Oct 23, 2002, 12:53 PM
Flying Welder Pilot
Plane Crazy's Avatar
Great Looking! Love the graphic details. Interested to hear your results on th LiPo's. I did not have the guts or the wallet to give them a try.
Gordon
Oct 23, 2002, 03:30 PM
2017 EDF Jet Jam, June 15-18
Robert Belluomini's Avatar
Your A4
Willerbee,
Your A4 looks phenominal!!!!!!
I can imagine the effort you put into detailing it.
I really look forward to getting mine done and flying.
Regarding batteries I am flying the sanyo 2600NiMH in my hotliner and I am very impressed. The voltage characteristics are higher than the cp2400 and the extra capacity does not hurt either.
Bob
Oct 23, 2002, 08:19 PM
EDF Jet Jam 2017, June 15-18
Kevin Cox's Avatar
"Wallet zapping vs LiPo suction" Hehehe, funny Herb
Looks great Willerbee.
Oct 23, 2002, 10:11 PM
shut up & fly
hoser's Avatar
wilerbee...well done looks fabulous!!!
what is the thickens of the gear wire looks thin for a 5+ pound plane?
how did you do the panel lines and the small lettering ?
Oct 23, 2002, 11:40 PM
Will commence ground testing of LiPO before committing to flight !
hoser, the struts are 1/8" thick, i did them a bit longer so it appears skinny, should hold o.k. but landings atill have to be close to perfect !! The panel lines are done with a Sharpie on the molded panel lines, the letterings are sprayed on.Would liked to have the wet transfer decals used by the RC jet set but too long of a wait. The decals are very scale.
Completed my 3.4 oz Tiny Danny Troy Scratchbuilt Indoor and Micro Models 28 Sep 26, 2002 04:51 PM
My first 4 channel? scream-n-leap Parkflyers 2 Aug 22, 2002 12:42 AM
Looking for Color Schemes for my Jepe F16 Joe Elston Electric Ducted Fan Jet Talk 7 Jun 28, 2002 05:39 AM
JePe A-4 Skyhawk Sture Smidt Electric Ducted Fan Jet Talk 51 May 28, 2002 02:04 PM
Jepe A-4 - retracts? ROG? randallp Electric Ducted Fan Jet Talk 17 May 01, 2002 05:19 PM
