Feb 14, 2007, 07:01 PM
Micro Zippy
jconwell's Avatar
What would I use to thin out contact cement?
Like the subject says: What would I use to thin out contact cement?
Feb 14, 2007, 08:22 PM
gbarc's Avatar
Use acetone.
Greg
Feb 14, 2007, 08:44 PM
is it flying time?
Jerry Combs's Avatar
A good idea Greg, unless he wants to use it on foam. Old fashioned lighter fluid will thin most contact cements. Rubbing alchol will also thin most of them. What every you use test to make sure that it is compatable with the materials that you want to use it on.
Jerry
Feb 14, 2007, 08:52 PM
Micro Zippy
jconwell's Avatar
Thanks for the advice. I've got some rubbing alchol in my med cabinat. I'll try that first. And nope, no foam...i'm using CF rods and ceran wrap
Feb 14, 2007, 10:08 PM
del
del
del's Avatar
There are water based contact cements...
--del
Feb 14, 2007, 11:33 PM
PGR
PGR
Low AltiDude
PGR's Avatar
Look on the container the cement comes in and see what they recommend for a cleanup solvent. Different cements will use different things.
I use Dap Weldwood Contact Cement and the correct solvent for it is Xylene. Xylene is cheap and easy to find so I have no reason to substitute something else.
Pete
Feb 15, 2007, 03:35 AM
3D Toy Designer
MicroRotors's Avatar
There are different types so it is always safe to read the can and see what it takes for clean up, it will tell you what to use.
Bill
May 21, 2021, 03:02 AM
Peter L Warren
On Thinning contact adhesive, advice was to see what is recomended for cleanup. Alcolin contact says acetone or thinners, but neither work to thin once the glue gets thick. It makes the glue separate and becomes stringy in both cases. I will try to get xylene, but not in local hardware stores.
May 22, 2021, 07:07 AM
aka crossup
Mr.Mayhem's Avatar
Ace, TrueValue and Homedepot stock it around here, should not be difficult to find it. Also a staple at marine supply stores. Worse case Amazon. Also it may be time for you to switch contact cements, many are available in fairly thin viscosity and dont forget spray types like 3M 77.
Jul 24, 2021, 09:00 AM
56S
56S
Certified Balsa Breaker
56S's Avatar
Having what's left of an old gallon of Dap Weldwood original contact cement I tried different solvents and finally found one that works. Calling Dap was no help. Acetone looked promising but after a few hours separated. Alchohol, mineral spirits and lacquer thinner didn't do it either. What did work and has stayed mixed for a week was Xylol. 6 bucks at the local farm store for a wuart. Yesterday I brushed a lite coat of thinned contact cement on a wing structure, waited two hours and applied painted 2um mylar. It went very well.
What would I use a Balacner for ? X3n0 Batteries and Chargers 22 Aug 11, 2006 11:47 AM
What is a Throttle Curve and Why Would I Use it on an Eco 8? wannabe Electric Heli Talk 7 Mar 31, 2004 07:08 PM
What would you use for 40-60A, approx. 480-720watts...? Magna Electric Power Systems 7 Jul 22, 2003 06:52 AM
what would be the best nicd battery combonation to use in a spirit with a power pod? drrhythm Electric Sailplanes 5 Jul 05, 2003 02:14 PM
What Can i use to thin 5 min epoxy? kushal_22 Electric Plane Talk 24 Mar 25, 2003 09:14 PM
