Feb 09, 2007, 09:09 PM
The ever learning newbie
Will this Foam Work For Covering H-J's Foamies?
I found this product walking through the local Wal-Mart today any ideas if this will work as a covering on H-J's foamies for example.....
http://www.darice.com/ecom/ProductDe...2-73&oid=23363
Feb 09, 2007, 10:06 PM
Happy2ndChildhood
Don McGill's Avatar
Good question. Same foam I picked up to try down the road. Since I am not the only one wondering, figured I'd get around to seeing if it sticks to glue and if wbpu adheres well to it. Does not stretch, so should be good I think if it adheres to the formers well. I figure it is really not sandable being that soft, so would need to cover it with wbpu and talc powder mix to get a hard surface for sealing, sanding and paint. If both of those adhere well, sure would be a nice super-easy to work with material for covering fuses.
https://www.rcgroups.com/forums/show...2&postcount=99
Let you know how it turns out in morn, I'm off to bed. Maybe in mean time we will get lucky and somebody will turn up that has already tried it.
Ok, stuck the 6mm Cellfoam88 on to the soft 2mm foam sheet with UHUpor, ...seems just as strong as depron to depron, good there. Added some smears of lightweight filler to my little experiment. Now really off to bed.
Last edited by Lakota; Feb 09, 2007 at 10:25 PM. Reason: Some of tests done before bed
Feb 10, 2007, 09:22 AM
Happy2ndChildhood
Don McGill's Avatar
I think this material will work well, but I am certainly no expert. I will be trying it if H-J designs another warbird, so we shall see. All three materials bonded nicely. the wbpu sealed nicely, but I have no talc on hand to try that mix. I see no reason it would not bond well since the wbpu does on its own.
Feb 11, 2007, 01:23 PM
Thanks Lakota
Thanks Lakota for the reply, but what is wbpu? I am looking forward to starting my mustang, I have also printed out the full size FW as well. I am hoping the spitfire shows up sometime as well.
Feb 12, 2007, 05:10 AM
Happy2ndChildhood
Don McGill's Avatar
water based polyurethane
preferably "satin"
Question Will this ESC work for my 3D plane? CactusJackSlade 3D Flying 1 Dec 30, 2003 05:23 AM
Will this setup work for Delta Wing? webnetxpress Foamies (Kits) 3 Apr 03, 2003 04:05 AM
Will this radio work for airplanes? DeaninMilwaukee Radios 0 Nov 10, 2002 12:30 PM
will this charger work for a 7.2v 270mAh battery? littleflyer Batteries and Chargers 0 Nov 08, 2002 06:11 PM
Will this setup work for TJ Jeremy_D Foamies (Kits) 2 Sep 17, 2001 09:34 PM
