Jan 11, 2007, 12:59 PM
crashinator
Lou Andrews Aero master bipe ?
i just purchased this kit NIB from an old time builder who passed away, from what i understand this used to be quite a nice plane, does any one have input on this model? Of the three building options, i plan to build with both wings swept, what are your thoughts on this build, ive only seen one of these planes fly.
Jan 11, 2007, 02:05 PM
Intermediate Multi
Trisquire's Avatar
I never owned one but it's always been one of my favorites. I saw several of them fly back in the old days. It's built like a tank by today's standards. Isn't the landing gear held in place with rubber bands? A handy feature. It will save you repair work some day.
So you're opting for the Jungmeister wing configuration. I would make the upper wing swept and leave the bottom wing straight like an old time Pitts. Either way, you can't go wrong with an Aeromaster. I'd love to have your plans when you're done.
Tom
Jan 12, 2007, 07:06 AM
crashinator
yes the LG is held on by #64s as are the wings!! i will make a couple copys of the prints before hand (im a little rough on prints!)
Jan 12, 2007, 07:15 AM
dusty bible = dirty life
Majortomski's Avatar
I had the last version from GP, they had changed the gear to soldered wire. The one piece aluminum that is in your kit works better.
I did the two short sweapt wings to but I modified the upper wings to have ailerons too.
Absoluly sweet flyer. Plan on a 90 FS or slightly bigger.
Jan 12, 2007, 11:07 AM
crashinator
i had actualy toyed with the idea of duel aileroonies, glad to see someone else did.
Jan 12, 2007, 11:54 AM
Just duplicate the aileron structrues in the upper wing. I put a single servo in each lower wing which linked to that aileron then a link from the TE of the lower aileron to the upper to drive the upper. Worked great.
Nunther bene of the AM is it fits in most cars in one piece.
Jan 12, 2007, 01:24 PM
crashinator
sounds good, once i finish some other projects, i'll start it, this will be my first no colored, high-lighted, glossy photos with step by step instructions with foot notes and builders tips, build!!!!
Jan 12, 2007, 04:21 PM
Looking forward to watching the build
Jan 12, 2007, 06:32 PM
Intermediate Multi
Trisquire's Avatar
I found a picture of numero uno. Looks like swept top wing, straight bottom wing. Can't tell if both wings have ailerons.
Tom
Jan 13, 2007, 10:07 AM
crashinator
i believe the kit calls for up to a .61 2stroke, but if i can pull off this build i may try to wedge in a .91 4stroke, i hope the wing load can take it!!
Jan 13, 2007, 11:17 AM
Intermediate Multi
Trisquire's Avatar
When 4-strokes first came on the scene, the rule-of-thumb was to double the displacement. .60 2-stroke => 1.20 4-stroke. I don't know if that's still the case. A .91 should be fine.
Tom
Jan 13, 2007, 11:38 AM
Mine first flew with a very old enya FS90, followed by a YS 91. power is not a problem for this plane.
Jan 13, 2007, 12:03 PM
Intermediate Multi
Trisquire's Avatar
I found another Ernie Huber shot:
Jan 13, 2007, 08:46 PM
Crashinator ,
The Aero master is a great sport plane , build it the way you like it , it will fly . I have flown several different Aero masters including my own ( short wings , sweep on top and straight bottom , ailerons on bottom only ) . Power was a good running .60 like ST. 60 or an O.S. . One thing I did notice on the Aero master was at at slow speeds , ( like high alpha drag it around on power nose high ) , the ailerons would fade away and rudder was needed to steer the plane . I still have a Andrews kit , it's one of my favorite planes and a honest flyer.
Mike 1484
Jan 15, 2007, 08:37 AM
crashinator
mike 1484, are you satisfied with the stock ailerons? i know its the original design but having flown it whats your opinion on duel ailers??
Yippee! Lou Andrews Aeromaster lt40 Flier The Builders Workshop 15 Nov 16, 2017 11:28 AM
Discussion stevens aero ultimate bipe? XarvoX 3D Flying 20 Sep 26, 2008 03:51 PM
Sold Lou Andrews Aeromaster Too kit pmisuinas Aircraft - Fuel - Airplanes (FS/W) 0 Sep 02, 2006 06:19 AM
For Sale Andrews Aeromaster Waco Bipe Twin Saito FA-60T & radio rtf (RTF) caf2461 Aircraft - Fuel - Airplanes (FS/W) 10 Dec 24, 2005 10:21 PM
FS: Lou Andrews' "Aeromaster Too" Kit NIB Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 2 Jul 03, 2005 08:23 PM
