Jan 09, 2007, 10:16 AM
jrb
jrb
Member
jrb's Avatar
AF 010 on 3S w/Graupner CAM 6x3 folder?
Anyone flying this combo?
What LiPos?
Other comments?
TIA,
Jim
Jan 09, 2007, 11:59 AM
Dr Kiwi's Avatar
How many turns/Kv?
Jan 09, 2007, 12:13 PM
jrb
jrb
Member
jrb's Avatar
14t
Jan 09, 2007, 12:28 PM
Dr John
pmpjohn's Avatar
This from the Astrofliht site on 3s
Prop Rpm Thrust Volts Amps Watts
EP 6030 GWS 14,400 rpm 11.0 oz 11.1 volts 6.9 amps 77 watts
6 X 4 APCE 12,800 rpm 10.9 oz 11.1 volts 10.4 amps 114 watts
EP 7035 GWS 12,700 rpm 14.2 oz 11.1 volts 10.6 amps 112 watts
Bob also states 7.5 amps max and sells the package with a 10 amp esc.
I normally use apc speed 400 pylon props 4-5" for DD and put it in a gearbox if I need to turn larger props.
Good idea to test with a wattmeter
John
Jan 09, 2007, 12:54 PM
jrb
jrb
Member
jrb's Avatar
Thanks John; that’s what got from his site too.
With TB18 they pull about 7 on GWS1300-2S, 11 amps w/either TP2100-3S or TP1350-3S – both @ storage level.
Not sure if 2S is quite enough; so I was soliciting experience of others.
One data point I saw was on 10x650NiMh with Dymond 6x4 folder trimmed to 5.5x4; same dims as the MAS prop that came with the motor – but blade shape?
Jan 09, 2007, 12:57 PM
E-Planes and Helis
Scott L. Sonder's Avatar
AF 010 with 6x3 prop
This set up is a little too hot for 3s lipos. I would not run this motor with 3s unless it was with a gearbox. I have 4 of these motors and I run them on 2s
600ma cells with the supplied 5.5x4 black MAS prop that astro recomends. I have 2 motors installed in a twin little stick that I run with a 1350 tp 2s pack.
Jan 09, 2007, 01:42 PM
jrb
jrb
Member
jrb's Avatar
Guess I’ll fly on 2S, and trim to less amps if I see the need for 3S.
Jan 09, 2007, 01:48 PM
vintage1's Avatar
I would..I tried the 6x3 folder on a permax 480 pulling 16A..it flew off in flight several times and finally shed a blade
Now I use that prop only on a 7.2v speed 400 on 3s LIPO..a nice tired pack that has enough go, but not too much...about 9V/8A..
If you want more an APC 6x4 is probably a better bet.
will a graupner CAM 6x3 folding prop fold backwards? downeym Electric Power Systems 6 Feb 08, 2004 10:56 PM
FS: Graupner CAM 6x3 Folding prop - for 3.2mm motor shaft JohnM Aircraft - Electric - Airplanes (FS/W) 16 Apr 08, 2003 06:27 AM
AF 010 on Kokams Tres Wright Parkflyers 64 Nov 12, 2002 02:44 PM
Astro 010 on 7 cells with 6-3 folder ? dvint Electric Plane Talk 2 Jun 23, 2001 07:50 PM
CAM 6x3 folder - best mtr/pack? hardlock Electric Plane Talk 7 May 16, 2001 03:54 AM
