Jan 08, 2007, 01:46 PM
1.21 Gigawatts!
Align 35A ESC Airplane Programming Question
I have a question about programming the Align 35A ESC for an airplane...i have a question on the timing setting and what the recommended setting is...please let me know if you are familiar with programming this ESC. Thanks!
dn
Jan 09, 2007, 09:11 PM
i use mid timming for motors that have more than 6 poles . high timming will add more power but the motor will run hotter with shorter run times .
Jan 09, 2007, 10:35 PM
1.21 Gigawatts!
i have learned a lot flying planes over the last 6/7 months but i don't know how to find the amountof poles in a motor, i know truns, kv, power draw etc...the motor i am using is a warp 4 4turn...any help would be appreciated.
dn
Jan 10, 2007, 11:30 PM
dn
you got me on that one. i fly mostly heli's and i know that the stock align 430l motor is a 6 pole and the speed control manuel say that low timeimng is for motor up to 6 poles. and that hight timeingf gives more power but heat goes up with lower flight times . i would use the mid timimg and go from there. i am putting thehsame speed control in a seagull 300l with a efite 480 brushless and will use mid timeing on that set up . good luck .
Jan 11, 2007, 11:18 AM
1.21 Gigawatts!
no worries, thanks mkeigwin.!
dn
Question Question about the Align 35A ESC jperch Mini Helis 11 Feb 24, 2006 04:29 PM
Question Align 35A ESC and Aon 3500 Motor TThroop Mini Helis 1 Jan 04, 2006 06:29 PM
Discussion Align 35A ESC programming problem Ohio AV8TOR Mini Helis 4 Jan 04, 2006 09:16 AM
Discussion How is the Governor on the Align 35A ESC? kenmalecki Mini Helis 0 Jan 01, 2006 10:35 PM
Align 35G ESC Soft Start Question AON-3500 goteron Mini Helis 0 Dec 17, 2005 08:09 PM
