Jan 07, 2010, 12:51 AM
KE your cub.
Curare's Avatar
I'd suggest balsa or Jelutong. Both are easy carving, and if you get the finish fine enough, you'll be able to pull straight off your plugs. The big problem I see is getting a frame to hold your plastic over the plug and box big enough to pull it down!
The over box idea looks okay, but I can see a spaz like me coming out with thir degreed burns on both arms, possibly a leg and a head too.
Jan 07, 2010, 03:09 AM
Prop Buster Extraordinaire
philba's Avatar
I just finished a vacuforming set up. Did a Dr Crash style platen and had a shop vac that really sucks. In a good way... Total cost including heater was < $30. First pull was good. really good.
The "oven" was a good find. I was in a thrift store and found an electric grilling pan that has a heating element in the lid. $4 for the whole thing (though I only wanted the lid). It heats really well and can do a 12" x 12" area though I made my frames for 9 x 7 material. It works great. the cool thing is the lid sits right on the frame perfectly. I've also seen electric hot tray heaters that could do around 12 x 18 though they didn't have the controller/power cord so I passed on them.
For making plugs, I've used water putty in an existing plastic cowling that was too flimsy. It produces good pulls. The nice thing about water putty is as it hardens, it firms up but is easily carved for about an hour. When it's hard you can sand it or even add more.
I also made a cowling plug with pink foam (extruded PS) and then glassed it with water based polyurethane. I put on about 5 coats. I was going to make a mold to to make a plug but thought, what the heck, and did a pull with it. To my surprise it came out good and the plug was fine. I made 2 more pulls on it and it looks ok.
Finally, I've heard good things about something called styro spray which is a 2 part epoxy like coating you put on foam. It sets up to a very hard surface and plugs made this way seem to last for a lot of pulls. https://www.rcgroups.com/forums/show...ht=styro+spray
check out TVCasualty's cowling and engine. I'll probably get some and give it a try. Carving foam is pretty easy.
Yesterday, 01:57 PM
Homemade tools guy here; not a spammer ( proof: http://www.homemadetools.net/links ).
Just a note that we featured your clever vacuum forming oven in today's HomemadeTools.net newsletter, at the link below:
http://mailchi.mp/buildthreads/multi...k-chair-342605
We know RCGroups.com; you guys are a good source of homemade tool ingenuity among forums. We've indexed 49 homemade tools so far from this site:
http://www.homemadetools.net/sites/rcgroups.com
I hope we've been able to send you some good traffic.
Make one 3s2p from two 3s1p ssstam Batteries and Chargers 2 Jun 08, 2005 05:48 AM
Plugs for vacuum forming zbrubaker Electric Plane Talk 12 Sep 18, 2002 04:45 PM
Cad drawings and vacuum forming flailing Vendor Talk 0 Aug 21, 2002 10:06 AM
Vacuum forming Fan-Fold zbrubaker Foamies (Kits) 4 Apr 29, 2002 11:23 PM
Vacuum forming options Slope Nut Power Systems 10 Nov 01, 2001 05:34 PM
