Sep 15, 2002, 07:59 PM
jmh
jmh
New Camera Mount Prevents Distortion
I solved the Mini PenCam distortion problem of taking pictures while under power. The solution is so simple that I'm surprised some of you had'nt figured it out by now. I will post a picture of this solution a little later (if there's any interest). Maybe someone would like to guess how to solve this problem? I am attaching a photo taken under full climbing power, you be the judge.
Sep 15, 2002, 08:01 PM
Leave me alone!
Martin Hunter's Avatar
Details, man, details!
Martin
Sep 15, 2002, 09:10 PM
Great! Please lets us know how you did it. I wrapped my camera in foamrubber which cut down on the waves a lot, but it's still noticable.
Sep 15, 2002, 09:11 PM
Call Me Interested!!!
VERY INTERESTED. DETAILS PLEASE!!
Sep 15, 2002, 09:18 PM
Look! Up in the sky!
eBird's Avatar
let's see...
the camera is hanging under the plane from kite string? no...
camera is out on a wingtip, away from the vibration? no...
swaddled in cushy foam? maybe...
I give up!
Cough it the 'tails!
Sep 15, 2002, 09:26 PM
jmh
jmh
ebird......you are getting very warm!!!!
Sep 15, 2002, 10:34 PM
Post them already!
Sep 15, 2002, 11:01 PM
jmh
jmh
O.K. this is what I did. I simply slung my camera assembly below my mounting support bracket. Not too close-- not to far. The first time I tried this, I took 19 total pictures......18 very good/1 bad. The bad picture was taken just before touchdown, very close to the ground. I will attach picture of mount. Notice there is only 3 lines supporting camera assembly. This can probably be improved on, but it is a good starting place. Please let me hear some feedback. jmh
Sep 15, 2002, 11:07 PM
jmh
jmh
Another view.............
Sep 15, 2002, 11:13 PM
Not sure I follow you with the pictures provided....
Can you describe the mount more? Perhaps talk about the materials used... Maybe a top down shot and stuff....
Sep 15, 2002, 11:41 PM
jmh
jmh
Sorry Cactus, maybe this will help. The wire structure hanging down from the fuselage boom is made of alum. welding rod. The blue camera box is foam. I taped some 1/32 plywood on top of the box. This all connects to the wire structure with 3 short lengths of nylon line. This help? The attached picture is to show the wire structure only(old picture).
Sep 15, 2002, 11:45 PM
I think I see it. I will have to do something different because mine is out of its case now and is powered by the triggering servo. 1.3 oz. I am trying different mounts and looking for a good point of view from the plane.
Sep 16, 2002, 06:50 PM
eBird's Avatar
JMH - I see your servo has a line attached, to "pull" and activate the shutter. Can you explain how this is set up?
I am planning on mounting the camera on thin ply, a servo on the same board, and have it "push" a rod into the shutter switch to activate.
I may alter my design based on your setup.
Sep 16, 2002, 08:37 PM
jmh
jmh
"Hello" eBird, Maybe this picture will help. Keep in mind there is a slot in the plywood that the clip-pin goes thru. This slot allows the servo to pull the clip-pin which trips the camera. This make sense? The clip-pin also makes it possible to remove the camera. Note that the small yellow tubing (ni-rod) stays on the camera (it is stuck thru the hole in the camera swivel) The clip-pin goes thru the plywood arm, and the yellow tubing(which is captured in the swivel). My old English teacher would rip me on this! jmh
Sep 16, 2002, 09:54 PM
Looks like a mouse trap, but if it works good...what the hay
