Dec 25, 2006, 03:34 PM
fly high ,land well
southern soarer uk's Avatar
lost foam method
I`m looking to use the lost foam method to make a fus , this will be my first attempt at this , is it totally neccessary to use carbon for the layup or is glass clothe ok , i`ve seen a couple of thread showing the basics and am wondering if anyone can give me a couple of tips or things to look out for when doing it, many thanks
Dec 25, 2006, 03:44 PM
that tree ate my plane
rotccapt's Avatar
i have used it for fiberglass with great results.
as far as tips go. do not use polyester resin with foam for it will melt all exposed serfaces. try to get the tape as wrinkle free as posible.
Dec 25, 2006, 03:59 PM
I've made more than a dozen pod and boom fuselages from 2-meter span to 15' span.
Please, give us the dimesions. Length. Maximum diameter. What kind of wing mounting? What kind of tail mounting? Desired weight and strength. What kind of plane; slope glider, thermal glider, electric, fuel powered, scale, etc.? Your design? A plan would be nice.
Dec 25, 2006, 04:43 PM
fly high ,land well
It`s going to be a jart for sloping, still waiting for the plan, i`m still at doing the homework stage
Dec 25, 2006, 07:32 PM
lensrc's Avatar
See this thread:
https://www.rcgroups.com/forums/showthread.php?t=521523
And for a lot more check the sticky in "Composite Fabrication"
https://www.rcgroups.com/forums/forumdisplay.php?f=210
Len
Dec 28, 2006, 05:31 PM
saucerguy's Avatar
structure
Discussion lost foam method southern soarer uk Slope 8 Dec 26, 2006 06:21 PM
Question What's a good foam to use for the "lost-foam" method Cziltang Brone Slope 25 Mar 14, 2006 11:51 AM
Lost Foam Method Question Screamin' Eagle Slope 5 Feb 20, 2005 02:53 PM
Lost foam Fuse question rlt55 Electric Sailplanes 9 Mar 07, 2002 06:28 PM
full fiberglass wings useing lost foam tec.? i-fly Electric Plane Talk 2 Jun 20, 2001 02:26 AM
