Dec 24, 2006, 03:45 PM
fly high ,land well
southern soarer uk's Avatar
lost foam method
Looking to start a new project in the new year possibly using the lost foam method for the fus, can any give me a link to a how to do lost foam, is this an expensive process? many thanks Harvey
Dec 24, 2006, 03:54 PM
Check out the JART build thread:
https://www.rcgroups.com/forums/show...ight=lost+foam
Here's one more:
Dec 24, 2006, 04:30 PM
fly high ,land well
Thanks socal bill
Dec 24, 2006, 05:20 PM
I like em strong & silent
Wingtech's Avatar
Lost foam
http://www.favonius.com/soaring/lost_foam/lost_foam.htm
Try this great site of master builder!!
Steve C
Dec 24, 2006, 06:22 PM
AKA Cactus
Phillybaby's Avatar
love the sock idea!!
tho i'm at a lost as to how you do the nose as the sock crunches up into a tight tube leaving a nip of nose sticking out.
heres the UK supplier
http://www.freeflightsupplies.co.uk/
under hi-tec mat
but the numbers are lost on me.
surely diameter and width are the same thing?
unless diameter is when it's round, width is pulled flat.
max dia 18mm isn't a big fuz.
Dec 26, 2006, 06:48 AM
He who dares ... repairs!
Hobster's Avatar
under hi-tec mat
Looks like it's only big enough for spar making. Had a quick look on the net - this company seems to sell the sizes required. Dont know if they ship small amounts to the UK though.
http://www.solarcomposites.com/compo...20sleeves.html
I have two mouldie wings (fvk absolute and mini graphite) without fuz's so interested to know how you get on...
Dec 26, 2006, 10:40 AM
Hobster
Spare fuselages are available for the FVK Absolute and FVK Mini Graphite
Brian
Dec 26, 2006, 03:51 PM
Hobster's Avatar
Thanks Brian, if my diy attempt doesn't work out I'll be in touch (if I ever get round to trying it)
Dec 26, 2006, 06:21 PM
AKA Cactus
Phillybaby's Avatar
can lost foam be used to make hollow moulded wings?
i guess most are produced plug style with the glass laid in a nice mould with balsa put in on top and maybe vac bagged or otherwise compressed.
is there any reason you couldn't do it the other way?
stick the balsa to a foam core, either with something just to hold it a bit like copydex, or even epoxy to help the laminate sandwich ( that has spars pre installed, and stuck very well to the balsa skin like you'd find in any hollow moulded wing ) then glass in the normal fashion
once it's done pour in your acetone and pour out the mess.
is there any reason we leave the foam in a wing after glassing?
this would save all the impossible task of making a reverse mould via CNC or which ever method for doing these style wings.
or am i missing something very fundamental here?
imagine being able to get a carbon sock big enough to do that in one go!
Discussion lost foam method southern soarer uk The Builders Workshop 5 Dec 28, 2006 05:31 PM
Question What's a good foam to use for the "lost-foam" method Cziltang Brone Slope 25 Mar 14, 2006 11:51 AM
Lost Foam Method Question Screamin' Eagle Slope 5 Feb 20, 2005 02:53 PM
Lost foam Fuse question rlt55 Electric Sailplanes 9 Mar 07, 2002 06:28 PM
full fiberglass wings useing lost foam tec.? i-fly Electric Plane Talk 2 Jun 20, 2001 02:26 AM
