Dec 23, 2006, 07:04 PM
FPV Enthusiast
martinic's Avatar
FAQ
Mini-Zoom/EP100/Hurricane 200/Pixie Zap Index - Links and Technical Information
This is an index to the Mini-Zoom posts on RCG. It contains links and information and will be enhanced and expanded as new and relevant information is posted.
Please feel free to add additional posts with technical information. Please do not post discussions in this thread.
The mother of all Mini Zoom posts, to which most of the following information is linked. This index is current to post 3227 in the thread.
General
Size comparisons
Models
  • Designed and manufactured in Taiwan by the GAUI company.
Stock Plastic
Technical Data
Materials: Plastic, foam blades
Price: $100 US (approx.)
Overall length: 310mm/345mm (including cabin & canopy)
Main rotor diameter: 340mm
Tail rotor diameter: 100mm
Rotor head assembly: CCPM control system
Motor: 180 size (brushed, standard)
Flying weight: 180-240g
Component Layout Photos
Setup Tips
Pro
Technical Data
Materials: Carbon fiber and aluminum frame, aluminum swash and head parts, plastic tail case/slider/grips, wood blades
Price: $200 US (approx.)
Motor: 180 size (not included)
Flying weight: 200-260g
Main drive gear: 120 Teeth
Tail drive gear ratio: 1:4 (64 tooth tail drive gear, 16 tooth tail shaft gear)
* The pro features adjustable servo mount points which allows for more servo options without modifications.
General Photos
Setup Tips
2S Setup
3S Setup
General
Flight Times
Pinions
This section from this post:
List from Darkhorse of suppliers of hornet pinions:
  • look around for hornet pinions
  • allerc.com
  • Pinion 16T-26T 3 mm Brass 64 pitch SLIP ON TYPE - $2.25
  • Pinion 16T-26T 3.175 mm (1/8 inch) Brass 64 pitch SLIP ON TYPE - $2.25
  • Pinion 10T-16T 2.3 mm Brass 64 pitch SLIP ON TYPE - $2.25
  • Pinion 13T-16T 3.175 mm (1/8 inch) Stainless Steel 64 pitch SLIP ON TYPE - $2.95
  • Pinion 10T-15T 2 mm Stainless Steel 64 pitch SLIP ON TYPE - $2.95
  • deeteeenterprises.com use to stock them and may have some old stock not listed on the site.
  • fxaeromodels.com may have 11T, 12T and 13T pinions for 2.3 mm.
  • www.abslotsport.biz (UK) have a wide selection of 2 mm pinions at 64 pitch.
  • towerhobbies.com
  • Pinion 16T-44T 3.175 mm (1/8 inch) 64 pitch grub screw $4.59
  • GWS EPS gears are 64 pitch/mod 0.4 push fit (glue or solder)
  • aeromicro.com
  • Pinion 10T-20T 2.0 mm GWS Pinion Gears for EPS-100C/-300C Drives $1.25
  • Pinion 12T-28T 2.3 mm GWS Pinion Gears for EPS-400C Drives $1.25
  • horizonhobby.com
  • Pinion 10T-20T 2.0 mm Brass Mod0.4 SLIP ON TYPE - $1.59
  • Pinion 17T-47T 3.175 mm (1/8 inch)64 pitch grub screw $4.75
  • More pinions at www.bphobbies.com
Batteries
General
2S Batteries
  • Aplus 2S 7.4V 850mAh 12C 46g 2.18 x 1.28 x 0.61" (55 x 32 x 15mm) ($17 US, Hong Kong)
  • Dualsky XP06202 2S 7.4V 1.24oz (35g) 2.16 x 1.18 x 0.39" (55 x 30 x 10mm) ($18.99 US, USA)
3S Batteries
  • Electrifly GPMP0805 3S 11.1V 640mAh 15C 1.9oz (54g) 2.48 x 0.47 x 1.29" (63 x 12 x 33mm)
  • Cellpro Kokam LiPoly 3S 11.1V 640mAh 15C 1.9oz (54g) 2.48 x 1.29 x 0.47" (Discontinued)
  • Dualsky XP06203 3S 11.1V 620mAh 15C/20C 1.58oz (45g) 2.16 x 1.18 x 0.59" (55 x 30 x 15 mm) ($24.99 US, USA) (Manufacturer Site, Review)
  • Aplus 3S 11.1V 850mAh 12C (65g) (53 x 30 x 20mm) ($25 US, Hong Kong)
  • HXT6203S/XP06203 hexTronik 620mAh 3S 11.1v 15C 1.58oz (45g) 2.16 x 1.18 x 0.59" (55 x 30 x 15mm) ($13.77 US, Hong Kong)
  • Vampower VP3S0620 620mAh 3S 11.1v 10C ($28.50 US USA)
  • Thunder Power TP-730-3SPLJ 730mAh 3S 11.1V 12-18C 49g (55 x 33 x 14mm) ($42.95 US, Canada)
Blades
Foam
Wood
Fiberglass
Carbon Fiber
Making Blades
Balancing Blades
Servos
General and Options
Pino
Technical Data
4.9g
torque at 4.8V = 300g/cm
speed at 4.8v 0.12sec/60į
Maxwell-MX306BB(High Speed)
Technical Data
This servo comes with JR/Hitec S Connector also known as a "Universal Connector". Even though this servo comes with JR/Hitec S Connectors, this servo is electrically compatible with Futaba receivers. Follow the wiring diagram below. If you hook this up incorrectly nothing bad will happen to the servo. Just flip the S connector and around and the servo will work correctly.
Carbon nylon gear
M6.4 ball bearing
Extra Strong torque with low signal affect and CE certification.
Waterproof case
Weight : 6.6 grams / 0.23oz.
Dimensions: 22 x 10 x 23 mm / 0.86 x 0.4 x 0.9 inch
Torque At 4.8V: 0.8kg/cm , 12 oz/in
Speed At 4.8V: 0.10 sec / 60 deg at no load
Motor Type: 3 pole magnetic motor
  • Same as the Blue Bird BMS-306 BB Servo
  • Same as the Waypoint W-060BB 6.0g BB Servo
Issues
Gyros
Videos
Crash Damage
3 Blade Head
GAUI Upgrades
K&T Upgrades
Paint Jobs and Canopy Options
Scale Fuselages
Online Vendors
Tools
Dec 23, 2006, 11:02 PM
Radd Graduate '06
Mochaboy's Avatar
EagleTree logs
14T/4800kv/2s 15c 850mah
https://www.rcgroups.com/forums/show...3&postcount=34
Old Mar 12, 2007, 12:24 AM
xjpeer
A moderator felt this post violated the following rule: Offensive content (Offsite link).
Apr 03, 2007, 12:28 PM
David1
bmw330i's Avatar
Online Vendor: RCMACHINE
Another Vendor on eBay:
I just bought a Pixy Zap Pro (EP100 Pro) from: http://stores.ebay.com/RCMachine
May 16, 2007, 12:59 PM
Bird of Pray
Flying Dutchy's Avatar
Hughes 300 3 blades flybarless version
https://www.rcgroups.com/forums/show...=670523&page=2
Jun 08, 2007, 12:18 PM
David1
bmw330i's Avatar
Another Vendor...
http://www.elemodel.com/ <--note must use Windows Internet Explorer for the shopping cart to work properly.
Jun 13, 2007, 05:06 PM
FPV Enthusiast
martinic's Avatar
Common crash parts
Blades, main shafts, landing gear, tail slider, screw kit, belt, main gear, flybar, tail fin.
Jul 07, 2007, 02:53 PM
Futaba servos upgrade on plastic chassis
https://www.rcgroups.com/forums/show...os#post7120327
Jul 11, 2007, 01:55 PM
I need some advis on ESC's I know i posted my own thread regarding this issue but that was before learning about this thread. I have an RC epert 30 A ESC ...will this be ok for the EP100 ? If not , its a brandnew ESC and i will post it in the for sale section and mabe see about a trade for one that will.
thanks
Jul 12, 2007, 10:09 AM
FPV Enthusiast
martinic's Avatar
It's a bit big at 30A - the EP100 works best with the lightest weight components. Many use a Castle Phoenix 10A or a 25A. You want a target weight of ~210-220g for the plastic EP100, ~220-240 for the Pro - thats' hard to reach.
Please keep questions out of this FAQ thread - it is only for posting information.
Jul 12, 2007, 10:25 AM
I apologys..thanks for the kind words at answering my question
again i apologys
Aug 07, 2007, 04:03 PM
Heli Hooligan
V2 Frame Electronics Installation
http://www.gaui.com.tw/images/ps/EP100V2.jpg
Aug 17, 2007, 12:18 PM
Inciting Riots
village_idiot's Avatar
BP hobbies is now carrying EP100 and Pixy Zap helis and parts
http://www.bphobbies.com/
Sep 07, 2007, 12:35 PM
Good
Nov 14, 2007, 02:01 AM
Anyone know why my Pixy Zap wobbles. I'm going to check if my main blades are balanced but besides that, is there any other reason anyone knows of?
Question EP100/Mini-zoom/Pixie Zap FMS simulator model??? village_idiot Micro Helis 0 Aug 12, 2007 12:59 PM
Question Mini-Zoom/EP100/Pixie Zap - Looking for a European seller! Xanix Micro Helis 0 May 22, 2007 02:42 AM
Sold PLEASE DELETE - Mini-zoom/EP100 Kit krispee Aircraft - Electric - Helis (FS/W) 1 Jan 07, 2007 08:16 PM
Discussion Mini-Zoom/EP100 Questions chris72983 Micro Helis 3 Jan 02, 2007 07:55 PM
Sold Mini-Zoom Pixy Zap EP100 Heli, Plus extras, brand new. code Aircraft - Electric - Helis (FS/W) 1 Dec 23, 2006 02:03 PM
