Gyrocopter Aerodynamics - Page 44 - RC Groups
This thread is privately moderated by mnowell129, who may elect to delete unwanted replies.
Mar 31, 2016, 11:41 AM
The extra centripetal force combined with larger hinge offsets would make it hard for the spindle to tilt. Slower body response.
Remember when the spindle tilts it has to pull the blades in essentially making your rotor disc shorter. The more offset the more it pulls thus the more the rotor fights the spindle tilt.
Mar 31, 2016, 12:38 PM
I'm not as bad as they say.
Originally Posted by grant31781
It seems like the main rotor would not need to teeter since the fly bar can. How does this differ from the gws Dragon fly head?
It doesn't need to, but early ones did. Very soon they adopted a snubber or damper to restrict the teetering motion and get more control power.
The GWS didn't teeter, but the blade holder arms were pretty flexible so they acted like a flapping hinge.
Note that when you make a rotor really, really rigid the phase angle changes to something less than 90, so you have to adjust the swashplate phasing and/or the flybar phasing angle. This is readily apparent in the small rigid rotor helicopters and the small ones with a flybar where the flybar is not 90 from the main rotor.
The bigger the rotor gets, the harder it is to make it truly rigid, but still the phase angle gets less than 90 and so the controls have to be adjusted accordingly, even on full sized helicopters.
Full sized gyrocopters have free teetering rotors with no snubbing so the phase angle is always 90. This is what makes the teetering spindle work in what looks to be the "correct" direction to apply cyclic in the right place. Unfortunately this leads the uninformed observer to incorrectly assume that the spindle tilts is actually just forcing the rotor in the desired direction by force. (A little thought about a teetering head will explain why this is impossible as no torque can be placed on the rotor through the teeter.)
This mistakenly leads to metal gear servos, when in fact the problem is the flapping hinge is too stiff and the centripetal forces in the 6/9 position (as you described, 90, 270 azimuth positions for the roll example) are too high for low power servos.
To add to this saga, when the flapping hinges are made flexible enough the coning gets higher and the following rate goes up, and the correct adjustment should be adding tip weight to reduce coning and following rate, but most people do something else, not understanding the root causes.
Fortunately some combinations can be made to work, so the exact blade/rotor/head/servo combination gets copied as it is known to work.
Latest blog entry: AIrcraft I've built.
Mar 31, 2016, 12:57 PM
Originally Posted by chadandrews
Thanks Mickey (or do you prefer Mick?). Couple of questions regarding the offset hinge.
1. Am I correct in thinking the heaver the blades, the more centripetal force will be created thus more feedback from the rotor disk is transferred to the rotor mast?
Yes
And thinking oppositely more control from the mast to the actual rotor plane.
No. This assumes that direct force on the blade is what is causing the rotor to move, which it is not.
Assume the blade at the 90 position in a CCW rotation rotor. If the mast is tilted left right at this position, this applies an upward downward force on the blade root only, as the tip will stay in plane. Due to the phase lag response of the blade, it will rise up fall a small amount, 90 later over the nose. This is not what you would expect for a left right spindle tilt. However. Now that the blade is over the nose, the left right spindle tilt increases the AOA of the entire blade producing significant up force. 90 later over the left hand side that blade has now reached its maximum change in position above the previous rotor plane position. For a teetering system the rotor is now tilted so that the rotor thrust is not aligned with the CG and a roll occurs. For an offset hinge system, the CG is not aligned with rotor thrust, AND the offset hinge arrangement applies a rotational torque to the shaft and the model rolls to the right.
Note that the response of the rotor blade to the cyclic input is governed by the blade mass, rpm and the instantaneous change in lift of the blade (the forcing function).
So the assumption you implied that tilting the shaft applies force to the blade to effect the control is not correct.
2. Am I correct in thinking the distance from the center of the mast to the hinge point acts like a lever for the above control, i.e. longer distance more control (longer moment?), shorter distance, less control. Control in this case being a function of the centripetal force the blades are putting on the offset hinge to pull the hub back into alignment with the plane?
Yes, ultimately with no hinge offset you have a teetering system, which is the least control authority (but also the highest following rate which leads to an aircraft with a very high reaction to the controls, but no real authority in the controls, making it difficult to fly, especially as the reaction rate (called the following rate) gets higher as the model gets smaller).
But the caveat is that the thing that makes the blade go out of plane to exert this torque is not direct input, but cyclic pitch.
As had been stated in the last couple of posts, in spindle tilt gyros, the flapping hinge is basically needed to decouple the centripetal force of the blade from the servo so the mast can be tilted.
Just want to understand cause and effect before I experiment.
Chad
Understood. Although lack of understanding hasn't stopped experimenting before. Even the pioneers built stuff before they understood it. But I think it makes experimenting easier with at least a cursory understanding of what's going on.
Mar 31, 2016, 01:01 PM
I found this about phase angle
http://blog.aopa.org/helicopter/?p=678
Some time in the past, it was decided to draw an analogy between a rotor and a gyroscope. Unfortunately, this analogy is incorrect and has caused confusion ever since. A rotor is not a gyroscope, due to the articulation, real or virtual, of its blades.
A rotor is a system of whirling pendulums, and its reaction to displacement inputs is governed by the laws of vibration. In accordance with those laws, the only time a rotor blade responds with a 90 degree phase lag to a cyclic control input is when that blade is hinged at the axis of rotation and does not include any pitch-flap coupling.
As the flapping hinge is displaced away from the axis of rotation, or as pitch-flap coupling is applied, the phase lag steadily reduces below 90 degrees due to the increase in natural frequency of the blade. In a given helicopter rotor, the phase lag also changes with the Lock number, i.e. increased aerodynamic damping reduces the blade natural frequency and thus increases the phase lag, such as would occur if flying one day in freezing conditions in Death Valley, and another day in hot weather at the top of Pike's Peak.
In summary, a rotor is a dynamic system in resonance, i.e. an oscillating system responding to periodic disturbances. All else follows.
The phase lag may be referred to as "precession", but this is a less than rigorous - and confusing - use of this term.
Mar 31, 2016, 01:02 PM
Hi Grant,
I appreciate your feedback, its really making me think. I still feel we are a little apart on timing though, but I do see what your explaining. And great point on pulling the rotor inwards, this would actually increase the rpm too. How interesting.
Mar 31, 2016, 01:13 PM
Not sure I got the quote function right below, but that was my ah-ha moment. Thanks Mickey
Assume the blade at the 90 position in a CCW rotation rotor. If the mast is tilted left at this position, this applies an upward force on the blade root only, as the tip will stay in plane. Due to the phase lag response of the blade, it will rise up a small amount, 90 later over the nose. This is not what you would expect for a left spindle tilt. However. Now that the blade is over the nose, the left spindle tilt increases the AOA of the entire blade producing significant up force. 90 later over the left hand side that blade has now reached its maximum change in position above the previous rotor plane position. For a teetering system the rotor is now tilted so that the rotor thrust is not aligned with the CG and a roll occurs. For an offset hinge system, the CG is not aligned with rotor thrust, AND the offset hinge arrangement applies a rotational torque to the shaft and the model rolls to the right.
Mar 31, 2016, 02:54 PM
You're welcome.
Note that I mixed some right/left/up/downs in the original post, I've since edited so it matches itself.
Sorry if this causes confusion.
Apr 12, 2016, 08:14 PM
scratch build
Hi and thanks to everyone who has contributed to this thread on autogyro.
I'm going to scratch build an autogyro and have been mulling over the concept of using a cyclic pitch head from a 450 helli. I have a 2 blade flybar head and a 3 blade fbl head to choose from and will use aerobalsa blades for this build.
The post about gyros by M. Nowell, and the head used there is really good but its a fixed pitch head and I'm not sure how to transform that theory into a cyclic pitch head version.
Has anyone tried a cyclic pitch head?
Has anyone got any ideas or theory they can share?
All and any help will be much appreciated and combined with the info that has already been posted in this thread I hope this build will fly successfully.
Nov 18, 2016, 12:36 PM
I just have to say, I LOVE this thread! I have probably read the original posts about 6 times now, and as I bounce around the hobby and come back to things with rotors I end up back here refreshing my memory. it is so well written, it's like reading something I wrote and almost forgot. (I am not saying that I could write that well.)
I am really glad it is "sticky".
Thank You!
May 04, 2017, 02:28 PM
Thoretical Question About Gyrocopters
Hi Mickey, I have an interesting question for you. At least, It's interesting to me I was wondering what your opinion is. Consider a Bensen-style gyrocopter, pusher configuration. Say someone was to build a human-powered gyrocopter. Full-scale. Pedal-powered. From the information I can gather, all successful HP airplanes have utilized a propeller, with varying diameters of @ 9 to 13 feet. So the mast has to be quite tall to allow keel tube clearance. My concern is the power push-over (PPO) characteristic. Since a HP gyroplane's pilot would only develop a very small percentage of the horsepower consistently (perhaps 1/4 to 1/2 horsepower max., compared to 40-90 hp for the typical gyrocopter) , would there be any need to keep the vertical CG at the thrust line ? The pilot's seat would have to be mounted, like 6 feet above the ground to align the vertical CG to accomplish this. My thoughts are that PPO would not become an issue, even if the pilot's seat (and vertical CG) is lower than the recommended alignment of thrust offset of +/_ 3/8".......the extra mast height would tend to increase pendulum stability, too. So, what do you think, Mick ??? Thanks for your help. Charlie Anderson
May 05, 2017, 09:59 AM
Depends on how much control power the main rotor has. PPO is basically an inertial coupling problem in an accelerating condition where the prop thrust provides an inertial (i.e. coupling against the inertia at the CG) nose down. This never happens unless accelerating because at steady state the rotor drag holds the aircraft in trim. I suspect with the low amount of instantaneous change in power from a human that PPO would likely never be a problem.
May 05, 2017, 01:59 PM
Hey Mickey, Thanks for your analysis and summary. I have constructed a HP gyrocopter, and have it 75 % completed. It swings a 10 foot prop, and will have a two-bladed rotor diameter of 25 feet. Very wide blades. The mast/gimbal assembly is over 12 feet tall, without teeter hub or rotor blades. I'm building a trailer for it right now. Basically all I have left to do is to construct the teeter spindle and rotor blades, and also construct a better propeller. A gentleman loaned me his HP airboat prop blades for some experiments, but at 8 foot diameter, they are too small, and not an efficient enough design. I built a longer prop hub for them, and will do some experiments with that setup anyways. Now I have a GoFundMe page, and hope to get the general public interested in contributing to my project. I've exhausted nearly all of my savings on this project, but it has been a dream of mine for 10 years. Contacted the local news station, but have not heard back from them. My copter is on the heavy side compared to modern HP airplanes, but will be in the weight range of very early 1960's HP birds. Aluminum construction. If I get enough funding, I can have a carbon-fiber fuselage made for it. Though I have designed and built this machine, I may actually be too heavy to make it fly, since I am @ 200 lbs. these days. Self-imposed all-up weight "limit"of other HP airplanes is @ 100 KG (220 lbs.) including pilot. No doubt, I will try it first !!! I'm sure there is a 120 lb. bicyclist out there somewhere, just waiting to make aviation history !!! Thanks again for your help, my friend !!! Charlie Anderson
Jul 05, 2017, 01:23 AM
I have posted this in the AC-10 gyro forum but received no answer; I'm not a gyro flyer, but bought the beautiful AC-10 when HK had a great sale. The weight lifted by two blades and a very small screw to keep the rotor attached to the mast have me skeptical. The YouTube videos are likewise not reassuring.
The rotor is now 3-bladed using the same CF blades.
1st try; accelerated very fast and straight but failed to get off the ground. One blade holder broke off. Very minor cosmetic repairs.
2nd try; Added a 1/32" shim to increase the blade angle. Made a stiffer plywood blade holder. Held full up per the instructions. Fast straight run and it lifted up, but immediately rolled 90 degrees left and did a knife edge left 120 degree turn all about waist high. I cut the throttle and it rolled upright all by itself and settled down for a smooth landing.
Getting ready for the 3rd try; Added a popsicle stick on top of the 1/32" shim to further increase the blade angle. The videos make me think the rotor speed is too slow and the flight speed is too high. I had another unsuccessful 1 flight 3-blade trainer gyro last year that used a template for a 7 degree left rotor tilt. It took off OK but when I started a careful turn to the left it immediately rolled right and nosed in. Do I need to tilt the rotor ? The AC-10 uses elevon type rotor tilt and a rudder. What inputs are needed to fly it?
Jul 09, 2017, 09:04 PM
Waited for comments about the need for rotor tilt and reason for the AC-10 rolling as it left the ground......nothing.
Tried again and again, as it lifted, it acted like it hit a hole and stumbled end over end. I will be salvaging reusable hardware.
Signing out
Jul 10, 2017, 12:15 PM
Forever WTTM Pilot #7
Buzz's Avatar
Jim.... Mine does the same thing on takeoff. When it lifts I have to be ready to give it right stick.
I think it's got to do with the torque of the blades trying to turn the gyro over. Be sure you're taking off into the wind and before you make your takeoff run....spin the rotors up with your finger.... as fast as you can. I hope this will help .... don't give up yet.
Buzz
