I Want see my F18 in flight
I've build, some time ago, an F18 from kevin plans. But I've a problem: he don't want fly!!!!
I don't know why! I use this setup: wemotec Mini fan 480 10 cell 800 AR 2 HS81 servo mini JR reciver jeti 350 controller weight: 950 gr. I hand launch the model, but he try to climb, but he's like a floating leaf, and retouch the ground after 30 meters. Waht can I do?? Do you have any ideas??? |
Andrea,
It looks like you need more power... I had the same problem with a speed 480 on 10 cells I switched to a HP 200/20/6 (brushed motor) and now it flies very well ! my setup is - minifan 480 - HP 200/20/6 - 10X 1300CP - around 1050 gr. - bungee launch - around 250W (350 would be better....) Olivier |
