Aug 16, 2016, 03:38 PM
skylane42's Avatar
Thanks for that info.. I tried to get the flybar off but the 2 small Phillips head screws are stuck.. and I am afraid to put too much force on them. If I heat the screws with a soldering gun ,, maybe they will break loose and I can further check out the head.
Aug 16, 2016, 07:53 PM
kodak_jack's Avatar
You have to be careful with the screw heads. If you round them out, you're in the crap. I bought a set of Phillip's head screw drivers at Radio Shack that were specifically for Japanese style heads.
Aug 17, 2016, 10:16 AM
Epilepsy Awareness
Flying High Mike's Avatar
Once you get the head off...leave it off. Take a small/short piece of CF (2mm), slide it through where the screws would go. Hold the CF in place with gas tubing. This will take the pressure off the flybar.
This mod started using a toothpick then went to CF round stock. I forget what they called this mod but, it works great toning down the TB effect.
If you need a pic, let me know.
Mike.
Aug 17, 2016, 10:28 AM
Epilepsy Awareness
Last post edited
Aug 17, 2016, 07:10 PM
kodak_jack's Avatar
Mike.
Yep, I forgot about that. One advantage is that instead of a U-shaped cap being in contact with the center pivot, the CF rod only gives you line contact.
Aug 18, 2016, 11:18 AM
Epilepsy Awareness
I had a pic in my own blog I had forgotten about We used to call it the "Bullet Mod."
https://www.rcgroups.com/forums/show...ostcount=10900
Mike.
Dec 30, 2017, 08:09 PM
I can't Spell RID
stsguy's Avatar
I have plenty of new for sale very cheap
Dec 30, 2017, 08:54 PM
kodak_jack's Avatar
So does everybody else. Mine is even brushless!
Dec 30, 2017, 09:30 PM
Epilepsy Awareness
You PM'd me. What do you mean you have plenty of new for cheap? What exactly are you talking about?
Mike.
Dec 31, 2017, 12:29 PM
"whirlydude"
flyeraroo's Avatar
Chap, you said you needed a 4 in 1 unit. Have you thought about using a 3 in 1 with a spektrum receiver, or wouldn't that work?
Jan 01, 2018, 02:00 PM
Epilepsy Awareness
Randy, how are you doing/feeling Sir? It's been a while. I hope you are doing much better. Yeah, I think I might have a 3in1 w/RX. IDK, did Esky also put out a 3in1 w/RX as a separate unit? It just might be for Spectrum and I have the DX9. I'll have to check that out Bud. I never thought of that
Wishing you a Happy New Year to you and yours.
Mike.
Jan 27, 2018, 11:44 PM
Epilepsy Awareness
I just found a 3in1 Spektrum. I'll post mod.#
Jan 28, 2018, 08:39 AM
kodak_jack's Avatar
Hey, Mikey, I'm looking at a 4-in-1 and two Aero-Nutz motors, with heat sink, all still mounted on a stock frame! I didn't hear you needed one. Remember, I went brushless on mine. Interested?
Jan 29, 2018, 12:12 PM
Epilepsy Awareness
Thank you Jack. I'll respond to your email BTW, is this the EFLH 1024?
Mike.
Jan 29, 2018, 12:13 PM
Epilepsy Awareness
I found a 3in1 unit but no RX
Discussion to buy or not to buy the blade cx2 airhead225 Coaxial Helicopters 37 Sep 01, 2019 09:05 PM
Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers Sirion Electric Plane Talk 11 Apr 19, 2009 07:52 PM
Question How to program my dx7 to fly blade cx2? topforce Coaxial Helicopters 4 Sep 23, 2007 09:13 AM
Discussion How do I use my ICE to charge my batterys for blade CX2??? Scale-Hobbies Electric Heli Talk 2 Jan 26, 2007 02:02 PM
Discussion How to learn to fly inverted with the Blade CP? Crazyrcer Micro Helis 4 Apr 05, 2006 12:59 PM
