Sep 09, 2002, 12:56 PM
asperkins's Avatar
My MM C180 (yes, another one)
Here is my new MM 180. I can already tell that I will have to buy each and every kit they make.
I was a bit impatient building it. I am too excited about flying it. As a result I'm not ovelry happy with my work.
I plan to buy another one and take my time and add additional scale details, including flaps and ailerons.
A couple of things I did different: I used aluminum tube and wire to mount the wing struts. I knew if I glued them as specified in the plans I would end up breaking them off. Also I used tape to attach the gear struts.
Sep 09, 2002, 02:39 PM
Palmettoflyer's Avatar
Great ideas! Your 180 looks good too.
I am still working on my MM 180. Some day soon it will be ready to show also.
Palmettoflyer
Sep 09, 2002, 03:55 PM
Under tension
citabria's Avatar
Nice job. I really like what you did with the wing struts. The original system works alright but I broke one of mine off before I even flew it.
Has anyoune notice that for a month we've seen no new 180's and all of a sudden there's been this massive barrage of finished models?
Sep 09, 2002, 04:09 PM
asperkins's Avatar
I originally got the idea for the struts from the 60" Dare Stinson Voyager I built. They work quite well with the voyager so I decided to try them on the 180.
The only issue I see is that there needs to be some amount of friction, or something else, to hold the struts in place. The Voyager had struts in a V formation so it wasn't an issue.
Sep 10, 2002, 02:37 AM
mefly2's Avatar
Looks great... ! I also like your idea for the struts, no you have me thinking. My struts are still in the sheet that they are cut from, I'll get to them someday... .
Bob
Sep 10, 2002, 10:02 AM
Leave me alone!
Martin Hunter's Avatar
Good thinking on the struts, and a good looking Cessna! Big fowler flaps do have a great appeal, don't they? Keep us posted if/when you do that!
Martin
Sep 10, 2002, 10:41 AM
asperkins's Avatar
If you add the aluminum tubes before you cover you can reinforce them buy sewing.
On the Stinson I used a sewing needle and thread to sew the tube to the balsa. Just a few loops through the balsa and over the tube, then a drop of CA. This provides a substantial amount of strength.
BTW, thanks for the complements.
I'm going to be more patient next time, no really I am. I want a better color scheme and some tricked out flaps and ailerons. Mine came out at 7.9oz AUW so I can afford a bit more weight.
