Jan 23, 2019, 06:37 AM
Too old to rock-n-roll...
TooJung2Die's Avatar
It's hard to see in the photo but the ailerons look like they're 1/3 the chord. How do you stiffen the ailerons so they don't twist flex when they're so thin? Are the servos wing mounted?
Jan 23, 2019, 10:53 AM
The ailerons are very weak and do flex but since the plane is so light it flies fine. Servos are mounted in the wing.
Maiden flight with spare wing. AUW is now only 191g.
90" electric glider (4 min 38 sec)
Jan 23, 2019, 04:45 PM
Live to fly... Fly to live
mudman1959's Avatar
Gone but not forgotten...
I built this one out of Dollar Tree Foam Board awhile back.It did Ok but had a nasty tendency to stall out in a turn and spiral down a bit. I finally figured that out and it ended it's life in the top of a tree. It was modeled after a Gentle Lady but with a bigger wing.
Glider flying.MOV (1 min 22 sec)
Jan 23, 2019, 06:50 PM
treefinder
springer's Avatar
If you're gonna put her in a tree, right at the top is best!!
Jan 24, 2019, 04:39 AM
It looks very majestic when flying. Seems like it can almost turn on a wingtip.
Jan 24, 2019, 11:15 AM
low tech high tech
vtdiy's Avatar
Mudman, great to see it flying. What was the cause of the stalling behavior that you worked out, and did you find a solution for that plane?
Nov 07, 2019, 06:21 PM
This is an old video of a simple motor glider.
Big Umx motor glider (2 min 53 sec)
Latest blog entry: DLG builds
Nov 10, 2019, 01:28 PM
Yenya's Avatar
Kaze 1.5m
Nice one, Boa. this thing floats! I wonder how you fix the wings to hold the dihedral.
Here is my foam glider Kaze:
(clickable image leads to the flight video)
Build from 3mm XPS foam, covered with 80 micron document laminating film. The wings are airfoiled, with foam ribs between the covering layers. Airfoils at the tip are AG38, at the center AG36, full flying H-stab with +- 90 degrees deflection, full-flying top part of the V-stab (about 45 degrees of deflection], 500g AUW, 9x6 folding prop, RaceStar 2208 KV1100 motor, 20A ESC, 3S 1300 mAh battery. The wing has 1.5 m span reinforced with a straight spar from 6mm x 1m carbon tube near the top surface, giving it a very small dihedral, plus the carbon tube flex. The fuselage is from 8mm carbon tube. Both tail surfaces are driven by pull-pull systems using kevlar fishing thread.
It has decent aerobatics capabilities, just the wing spar is too weak and bends in high-g manoeuvers. It also glides well, I measured it to be under 1 m/s Z-axis speed (how is it called in English? I mean it losses under 1 m of height per second). This can be acchieved only in light wind conditions, the small dihedral means that it has to be piloted all the time. But on the other hand, it also flies inverted decently, and the loop with 90 elevator deflection can be done literally around its CG.
Nov 10, 2019, 01:56 PM
Jack
jackerbes's Avatar
My 96" span scratchbuilt foam glider is a wonderful flyer and the wing loading is about as light as glider builds get.
AUW: 1460 grams = 51.5 oz.
Wing Loading: 9.4 oz./sq. ft. or 28.5 grams/dm2
I posted the details on my 96" span Big Blu 96" span glider in this post:
https://www.rcgroups.com/forums/show...&postcount=236
I used the sailplane calc software to get an idea as to things like the wing and fuslage layout and size (this was my first ever serious glider build).
Sailplane Calc can be downloaded here:
http://www.tailwindgliders.com/Files.html
This issue of the RC Soaring Digest magazine has a great article on using the Sailplane Calc software:
http://www.rcsoaringdigest.com/pdfs/...SD-2008-04.pdf
Jack
Nov 10, 2019, 03:28 PM
An itch?. Scratch build.
eflightray's Avatar
Based on a plan called the Condor, 80" span, Speed 600 motor, Nimh pack, (it's a bit ancient but still flown).
(Not exactly foam though)
Nov 10, 2019, 05:42 PM
My new foam board motor glider is going to look like an extended wing DLG. Very light with a 20g motor, folding prop, UMX brushless receiver, and a 2s300mA battery.
Yesterday, 08:56 PM
72" wing without flaperons is 68g.
Today, 11:04 AM
Foamy and Glider fanatic
Blacky's Boy's Avatar
My "scratch built" motor glider
Here's mine. Built from a set of wings from an old bungee launch glider that one of my RC flying club members gave me.
It's got an arrow shaft boom, and a pod build from foam board and based off of the OSG. The vertical and horizontal stab are tape covered foam.
Franken Glider 08 24 2019 (1 min 48 sec)
Discussion Show Us Your Easy Glider! Capgun_Slim Foamies (Kits) 231 Aug 03, 2014 02:07 AM
Show us your airplanes! sneu Electric Plane Talk 21 Sep 20, 2009 01:03 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 08:23 PM
Show us your wildest Zagi Dave Seay Foamies (Kits) 9 Jan 23, 2002 02:22 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 11:50 AM
