Oct 16, 2006, 04:42 AM
Launchpad McQuack
Prop-er's Avatar
Cool
···Prop-er's 30" Pond racer (full-fuses)···
I've been working on pond racer plans before, but never got to finish them, since I wanted it to be too large, and too much scale.
https://www.rcgroups.com/forums/showthread.php?t=462433
When I saw Stringfly's shockflier style Pond Racer it started itching again. Check out these earlier thread's of scratchbuild PR's:
https://www.rcgroups.com/forums/showthread.php?t=578738
https://www.rcgroups.com/forums/showthread.php?t=312443
https://www.rcgroups.com/forums/showthread.php?t=470701
Scott J's fantastic PR build:
https://www.rcgroups.com/forums/showthread.php?t=530537
Video: https://www.rcgroups.com/forums/showthread.php?t=535588
As of today 've got two whole weeks vacation. Hopefully this will enable me to produce free plans for something flyable.
Material will be 6mm depron or FFF, wingspan 30". Construction will be comparable with Scott J's version. (sanded down depron)
I've chosen two Himodel 282616 1611KV Brushless Outrunners to drive this speed monster. I've got very good results with this very cheap motor in my Duplex Delta. If you mount a APC E 6 x 5,5 prop, current will be 10A. This means you can use two budget and light 10A ESC's, or one 25A ESC.
This morning I've modeled the motor, and the pond racer topview:
Best regards,
Vincent
__________________________________________________ _____________
Update Juli 2009:
The plans are up for grabs:
http://www.rcplans.nl/catalog/produ...&products_id=46
Have fun, and don't forget to show your progress in this thread!
Vincent
Oct 16, 2006, 07:25 AM
JAM
JAM
MaxAmps CMO
JAM's Avatar
I just love watching these 3D drawings come together.........I will be watching Proper........so far it looks good.
JAM
Jason
Oct 16, 2006, 03:41 PM
Lazy Builder
Oh boy oh boy oh boy oh boy, finally plans for a full fuse pond racer! I've always wanted to build one of these and now I will be able to. Thanks Prop-er!
Oct 17, 2006, 07:52 AM
Launchpad McQuack
Prop-er's Avatar
Modeled the fuses today. At first I'd drawn a fuse out of 4 plates. (rectangular section). I thought it was better to have a polygon section. Less sanding, and easier to get the difficult shape just right. Little bit harder to glue together.
Next up is the cockpit.
Vincent
Oct 17, 2006, 09:39 AM
Launchpad McQuack
Prop-er's Avatar
All parts modeled. The cockpit top panel will consist of double or even triple plates, since it must be sanded quite heavily to create the desired round shape.
What do you think?
Oct 17, 2006, 09:50 AM
DDC Rules!
Hi Prop-er,
it looks really great!!! (keep it up!)
one thing that's bothering me, is that with those lovely shapes, isn't it going to be a bit tough to get the two fuselages with exactly the same shape?
How are you planing to cut them?
Dan
Oct 17, 2006, 10:06 AM
Launchpad McQuack
Prop-er's Avatar
Good question. The fuses will consist of 8 outer parts. Formers inside will force the fuse to follow the right curves. The formers will have tabs which fit into holes in the fuse shell parts.
Since there's no flat bottom to start with, I will include on the plan a simple support construction which you can fix on your building board.
This way both fuses will have exactly the same shape.
Oct 17, 2006, 10:27 AM
Launchpad McQuack
Prop-er's Avatar
Underside. Cockpit changed from surface to solids model.
Oct 17, 2006, 10:44 AM
-+- PhlatBoyz -+-
kram242's Avatar
I love it.. Can't wait.. Are you using Rhino to model?
Oct 17, 2006, 12:11 PM
looks beter and better
Oct 17, 2006, 03:21 PM
Launchpad McQuack
Prop-er's Avatar
Yes, it's Rhino. Nothing else comes even close. Got a busy day tomorrow. See you thursday with more PR news.
Oct 17, 2006, 05:36 PM
registered foam addict
chara's Avatar
One of my absolute favorites! the pods are a challange. Bring it on Prop-er!!!!
Oct 17, 2006, 09:27 PM
STRINGFLY's Avatar
Nice....
Very nice Prop-er. Just great modeling and graphics. Mine looks pretty plain to that. Yours wll look great in full 3D. STRINGFLY <>++++
Oct 19, 2006, 06:47 AM
Launchpad McQuack
Prop-er's Avatar
It's coming together nicely. Got the cockpit and the pods parts unrolled and got the pods formers and the firewall finished.
Next up are the cockpit formers, prop spinners and air intakes.
Oct 19, 2006, 07:08 AM
Appie's Avatar
Prop-er,
Nice project you have going here, SUPER
It should be possible to build an all wood or even better all composite glasfibre one also with the plans you draw up..........i think
I'll be following this one closely
Success,
Appie
Burt Rutan's Pond Racer, Shockflyer Style IAD Foamies (Kits) 36 Mar 24, 2009 06:52 PM
NEED 3-VIEW FOR POND RACER N221BP joe Electric Plane Talk 18 Jun 22, 2008 04:55 AM
Gallery Burt Rutan's "Pond Racer" Prop-er Scale Kit/Scratch Built 63 May 07, 2007 09:03 PM
Pond Racer samo Scale Kit/Scratch Built 12 Aug 06, 2001 11:21 PM
What's better Regular Litestick of Full Fuse Lite Stick? mrebman Parkflyers 1 Apr 27, 2001 01:23 AM
