This thread is privately moderated by Lt.Smash, who may elect to delete unwanted replies.
Oct 09, 2006, 07:57 AM
Trader Rating: 51
For Sale
DYNAM 25AMP ESC and Jeti Programming Card
GraysonHobby only has 5 bundles that we are doing at this price, so act fast!
Dynam 25amp ESC and Jeti Programming Card $30 shipped to your door.
These super reliable controllers have: Very smooth throttle response; Superb operation with OUTRUNNER motors; Automatic motor cutoff with automatic detection of the number and the type of battery cells; Safety cutoff when using Lithium batteries that prevents accidental destruction of the Lithium battery due to over discharge; High frequency brake with non linear hard or limited braking action; Automatic self-calibrating when you turn on your transmitter; Automatic motor cutoff when battery voltage is low; 8 kHz switching rate. These can be easily programmed to operate either normal brushless motors or to operate OUTRUNNER motors.
Technical Data
  • Weight: 21 g
  • Low Resitance, 0.013 oHms, same as castle creations!
  • Use with Ni-Cd,Ni-Mh, Li-Ion, and Li-Poly batteries
  • Auto throttle calibration
  • AUTO CELL DETECT!!!
  • BEC 2 Li-Poly=4 servos, 3 Li-Poly =3 servos
  • Hard or Soft brake
  • High rate Switching, 8kHz
  • Voltage cutoff Set at 2.75V/cell
Additional programmable features with the Jeti Programming card:
  • Hard /Soft Brake
  • Battery type
  • High (3.0V/cell)/Low (2.75V/cell) Cutoff
  • Hard Cutoff or Slow down
  • Brake ON/OFF
  • Timing for Outrunners/Inrunners
  • Throttle Curve Linear/Logarithmic
More Info (Manual)
PM for payment please!
LT...
Oct 09, 2006, 10:16 AM
Trader Rating: 25
Check your PM
Oct 11, 2006, 03:40 PM
Trader Rating: 51
2 Remaining!
Found Wanted: Jeti programming card slo_dave Aircraft - General - Radio Equipment (FS/W) 2 Sep 16, 2006 07:00 PM
Off Site Dynam A22-15M and Dynam 25Amp ESC Jerry3644 Aircraft - Electric - Power Systems (FS/W) 1 Aug 20, 2006 10:52 PM
For Sale Axi 2204/54 & Jeti Advance PLUS 4 Amp ESC with programming card j_z_123 Aircraft - Electric - Airplanes (FS/W) 5 Oct 12, 2005 07:52 PM
Jeti programming card - weird or what? jeezeypeeps Electric Power Systems 1 Feb 01, 2005 06:59 PM
