Sep 04, 2006, 09:31 PM
Not a Doctor
me_wantee's Avatar
Idea
'Building foam sheet aircraft'
Why didn't I put this in post 1 in the first place
The idea of this list is to provide up to date details of all types of foam stockists from around the country.
To add a supplier, please send me a PM with details.
NSW
Aerodynamic Developments http://www.aeromfg.com.au/
Unit 8, 171-175 Newton Rd
Wetherill Park NSW 2164
Tel (02) 8788 9555
Fax (02) 9604 7468
Stocks Blue Foam
Australian Urethane & Styrene in Western Sydney http://www.ausurethane.com/index.html
Call James Pace on 02 96768444
Can cut blue foam or different grades (weights) of white foam to any thickness you want but not all foam is in stock. Seems they have very large blocks and asked for a few days to cut to size or get the stock in.
IInsulation Industries (Newcastle)
119 Broadmeadow Road BROADMEADOW NSW 2292
Phone: (02) 4969 5059
Blue foam and some other foams as well.
HStore
Suite 5A , 522 The Kingsway
Miranda, Kingsway
NSW 2228
Stocks Depron
North Coast Hobbies
172 Molesworth Street
Lismore
NSW 2480
Stocks Depron
VIC
Aussieflight
http://www.aussieflight.com.au
Contact Richard (Active RCG Member - send a PM to woodsy)
stocks CF88 in 3mm, 5mm & 10mm
Kitehouse (27 Cox St, Port Fairy) [email protected]
Contact Tim Mellor (Active RC Groups member)
stocking 3 and 6mm Cellfoam 88. Also Carbon spars and rod.
Ozhobby (Melbourne) www.ozhobby.com
Stocks EPP in various thicknesses from 10 to 60mm
541-583 Kororoit Creek Road
Altona, VIC 3018
Tel (03) 9226 3961
Fax (03) 9226 3963
Stocks Blue Foam
Hawthorn Hobbies
733 Burwood Rd
Hawthorn East
VIC 3123
Stocks Depron
Roj's Hobbies
136 Wingrove Street
Fairfield
VIC 3078
Tel: 03 9482 7555
Stocks Depron
PJ'S Hobbies
83 Rutherford Street
Swan Hill
VIC 3585
Tel: 03 5032 28
Stocks Depron
EPS (Expanded PolyStyrene)
EPS - 2400mm x 1200mm x 10mm SL Grade price - $ 10.00 + GST but we
EPS 2400mm x 1200mm x 13mm SL Grade (our smallest size in stock) price $ 13.47 + GST.
2400mm x 1200mm x 13mm 100mm ( 7 sizes ) density SL Grade, price dependent on size chosen. more densities available ( L, M, H, VH )
PolyFoam Australia
http://www.polyfoam.com.au
32 Dandenong Street, Dandenong
Business hours 8.30am 5.00pm Mon-Fri.
EPP(expanded polypropylene)
EPP sheet 1200mm x 900mm x 100mm White density 30grams per litre - $ 120.00 + GST. Able to cut the sheet to a minimum of 10mm, a cutting fee of $ 20.00 is charged.
These people even advertise that it is used for model planes aswell.
PolyFoam Australia
Depron
Dark Grey and white sheets in various sizes but sandwiched in between 2 peices of cardboard. Makes it very stiff and a little heavy but means you won't need carbon rods on planes such a profile pusher jets.
The card board can maybe be peeled off with some spray on stuff too.
420x600x5mm=$7.00
600x840x5mm=$10.00
800x1000x5mm=$16.00
http://www.riotstores.com.au
various locations Australia.
ACT
Monaro Models
180 Crawford Street
Queanbeyan
NSW 2620
Stocks Depron
QLD
48 The Promenade, Hendra, QLD 4011
Tel; 07 3268 3706
Fax; 07 3268 1041
Stocks Blue Foam
WA
Radiant Floor Heating Pty Ltd
Unit 5/21 Delage Street
Joondalup WA 6027
Phone 08 9301 5337
Fax 08 9301 5339
FOAM SALES
82 Norma Rd
Booragoon WA
(08)9330 1199
SA
NT
TAS
In Tasmania, both blue and white foams of differing densities can be bought from The Fibreglass Shop, Hobart. Contact Chris
Not to mention most of the standard weaves of carbon, kevlar & fibreglass cloth and a full range of resins. Run by enthusiasts too.
The Fibreglass Shop
202 - 204 Argyle Street
Hobart Tasmania 7000.
Telephone:, (03) 6234 2689.
Facsimile:, (03) 6234 3370.
email:, [email protected]
Sep 04, 2006, 09:42 PM
Next time I'll ARTF...
glydr's Avatar
Hi me wantee,
Is that 'me wantee new planeee'??
Anyhow - have a look also at this part of the forum:
https://www.rcgroups.com/forums/showthread.php?t=554951
Enjoy!
Sep 04, 2006, 10:02 PM
Not a Doctor
me_wantee's Avatar
"Me" always "Wantee" new planes.
Its actually my online poker nick and it came from a gameshow on the Simpsons. I use it for most online stuff now.
My wife is aware of about half the hanger, maybee just under.
The hanger also doubles as my office, much to the dismay of my staff.
Thanks for the link Glydr. I now definatly know where to head when I get the urge to ruin some perfectly good Depron sheets. (which is usually about once a month).
Sep 05, 2006, 12:16 AM
Just one more.......
Sim69's Avatar
Hi me wantee,
Also another nice 3d model not mentioned on the page that glydr posted is an EDGE 540T by Tim Hart ( www.foamyfactory.com ). 45 inch wing span!!! The plans are a little basic but if you've built a few foamies it's no problem.
https://www.rcgroups.com/forums/show...t=528943&pp=15
Sep 05, 2006, 03:33 AM
Not a Doctor
me_wantee's Avatar
I've seen the edge before, It's a great looking plane. I'll do one one day.
I had a better chance to go through Glydr's thread link.
There are some great plans in there for sure.
I got chance to do another half hour this afternoon, here's the progress pic.
Nothing glued yet, just taped the ailerons. She's shaping up to be a nice looking bird.
Sep 05, 2006, 04:33 AM
Sukhoi SU-27 Shock Flyer
Is someone here able to tile these onto A4 size paper so they are the same specs as the one hobby-lobby sells? http://www.hobby-lobby.com/shockflyer-su27.htm
Sep 05, 2006, 05:15 AM
Sim69's Avatar
Hi GuyP,
I bought an excellent program called tile print http://www.blackflight.com/tileprint/ $15.95 US that will do that for you. If you build from plans you download a lot it's a great investment. All you need is a measurement of some sort, millimeters or inches of one of the surfaces, (usually a scale down in the bottom corner) and the program does the rest.
Sep 05, 2006, 07:52 AM
Only one more Honey
bidlynd's Avatar
Hi Guyp,
Here is the link to the tiled plans https://www.rcgroups.com/forums/show...ns#post3554863
Just reduce or enlarge in a photocopier as required.
Not exactly what you wanted hope this helps.
Lyndon
Sep 05, 2006, 08:28 AM
Martini101's Avatar
how do you even build your own plane. I'm only 13 and it seems soo hard to me.
Sep 05, 2006, 06:00 PM
glydr's Avatar
Read through the scratchbuilt foamy thread and have a go.
https://www.rcgroups.com/forums/forumdisplay.php?f=428
Or you could buy a kit and learn from that.
Experience is the best teacher.
Sep 05, 2006, 08:12 PM
Volta was revolting
old man emu's Avatar
Martini,
In another thread you indicated that you bought a plane from Magnum and he was giving you some advice about it.
Well, what we have been saying is that young fellows like you should approach people like Magnum for advice. I'm sure that Magnum would be pleased to offer you guidance and advice if you haven't you met other flyers in your local area yet.
Everyone starts sometime. You're only 13. I didn't start until I was way older. Your only problem is getting cashed up to buy the hardware needed to build. Get out and mow lawns, sweep paths, mug old ladies.
Oh, and start simple. If you try to win an international scale competition with the first plane you build, you won't be happy. And you won't get much flying either.
Now go and PM Magnum
Old Man Emu
Sep 05, 2006, 11:47 PM
Originally Posted by bidlynd
Hi Guyp,
Lyndon
Thanks Lyndon,
Excactly what i'm after, just the right scaleing too
cheers-Guy
Sep 06, 2006, 12:36 AM
GOK
GOK
Loads of very nice jet plans on this page as well.
Both ducted fans and pushers. I fly the T-38 and the F15 from this site both beautiful flyers.
http://www.parkjets.com/
Cheers,
GOK
Sep 06, 2006, 03:20 AM
Only one more Honey
bidlynd's Avatar
Hi Guy,
No worries, a pic to get you inspired
US Depron & Foam Sheet Sources Gordon Johnson Scratchbuilt Indoor and Micro Models 26 May 21, 2008 10:45 PM
Where to get 3/16 foam sheet? JamesD Parkflyers 1 Jun 30, 2002 09:35 AM
Yippee! WTB-Foam Electric Aircraft SeanHagan Aircraft - Fuel - Airplanes (FS/W) 0 May 13, 2002 01:56 PM
epp foam sheet/block wholesale source opualuan Foamies (Kits) 4 Oct 02, 2001 10:26 AM
Arcel foam sheet source? hardlock Power Systems 3 May 21, 2001 08:24 PM
