Aug 25, 2006, 08:17 PM
↓↘→ + (punch)
theKM's Avatar
in-flight RPM for micro racers without a data logger...
This will really just sound like an ad, but during a troll through HobbyLobby, there are these just released new line of JETI controllers, called "SPIN"...
http://www.hobby-lobby.com/jetispin.htm
...you can hook the ESC up to their controller box jigger, and it'll tell you the max RPM for the flight. Seems like a way to get that RPM reading eithout carting dead weight of the data logger. I don't know about the performance itself, but seize and weight of the 22A seems to be that around the Phoenix25. Also seems to have a bunch of setting options.
Anyways, may be worth considering ...I know there's a few people out there that want in flight RPM's without the room for a data logger
Aug 25, 2006, 09:01 PM
@theKM,
It's not only the Rpm's that is interresting but also max. and min. currents/volts/temps and those are also readable.
I am not sure but I also think you can read the faults when the esc switches off so that you can if it was a overcurrent/temp at a what volts.
That way at least you can learn something about that, because maybe youre can see if youre motor is getting faulty/demagged
Grtz,
Heino
Aug 25, 2006, 09:17 PM
Plays with Toys
tim_mellor's Avatar
Also in a similar style check out MGM Compro "Black Box" http://www.mgm-compro.com
These apparently work great.
Tim
Aug 25, 2006, 11:08 PM
↓↘→ + (punch)
theKM's Avatar
Tim
wow, they do look fantastic. I've never even seen these puppies before. They do have a healthy price tag though.
Aug 25, 2006, 11:14 PM
Plays with Toys
tim_mellor's Avatar
Like all good toys they are expensive I have been using some of there smaller ESC's for a while, and I have a larger one (90A) to try out on an 8S setup, but I decided the black box was a little expensive even for my extensive collection .
Tim
Discussion Checking Amps & RPM without a data logger?? All__talk Electric Heli Talk 2 Apr 06, 2007 04:53 PM
Cheap in-flight RPM idea... meteor Power Systems 0 Jan 22, 2004 11:59 AM
Any interest in a belt drive for micro helis? Steve McBride Micro Helis 16 Nov 14, 2003 01:33 PM
Record Flight Time for a Micro? Steve McBride Micro Helis 7 Jul 05, 2003 05:36 AM
WTT-standard size flight pack for micro size 3DTRYER Aircraft - Electric - Airplanes (FS/W) 0 Dec 11, 2002 03:32 PM
