It looks like it will absorb a straight down plop ok, but the leg will bend back if the plane is driven in hard. I didn't want to glue in the stock GWS plastic part, I made this so I could unscrew and repair the nose gear. I went with the stock GWS wire, thinking it will bend rather than rip out the mounting.
The counter, none counter rotating prop argument got me thinking. I was was not sure but checked my photographs again
Man, I've got 5 flights on this beast, and each landing was progressively worse! Last weekend I over flared, bonked it on its nose and dinged both wing tips. This weekend I was up about 5 feet on approach, must have got too slow, stalled, and it flipped over and hit the ground inverted. Suprisingly little damage, mostly flattened the nose and ground off more wing tips.
Guess I need to work on coming in a little faster and smoother, with some power on all the way in. At least thats the theory. |
Might try flaps, would be pretty easy to hook up with a single servo. Yesterday had a good smooth landing with a bit of power on all the way to the ground. We are lucky to have a huge paved lot so you can really take your time setting it down. |
Hi Larry076,
"Washout" could be added by heating the wing tip portions and manually twisting the wing tips. But you have to take great care when doing this, apply hair dryer to heat the foam, keep the dryer 2" - 3" away from the foam, then heat it for 5 seconds, then twist it, repeat these until you make it on both tips. Probably hot water can be used instead. Just my two cents. Well, adding flaps is actually safer and better than this way. Chen |
My LHS ordered 2 of these for me over 2 years ago and i never picked em up. I went back last week and there still on the shelf !?
Figured someone would buy em, guess thats not the case with GWS anymore. |
Hi,I just got a gws p-38 from my wife for my birthday...it has the brushed motors...i was wondering what brushless setup i could use....motors,escs,etc....
It will be the first time i put a plane together and i would like to do it right...I don't want a speed demon...lol...i like scale flying....I would also like to use the 3 bladed props from gws.. Thank you in advance for your suggestions. |
Biggest tip is getting a good solid battery. Remember, you are essentially running two power trains off a single energy source. The P-38 flies GREAT but really doen't like to loose a motor. More P-38's have been lost due to a motor cutting out and the plane flupping over with the resultant crash.
Good luck! Jim |
Thread Tools | |
Similar Threads | |||||
Discussion | Gws 二次大戰 名機 Gws-38 | GWS CHEN | Japan | 6 | Jan 01, 2007 11:36 AM |
GWS-38 Twin Fighter | Randori | Vendor Talk | 154 | Dec 13, 2006 03:35 PM | |
Discussion | GWS-38 soon 廣營新的戰鬥機即將上市. | GWS CHEN | Taiwan | 15 | Dec 12, 2006 12:35 AM |
New Product | ****Must check GWS New Airplane GWS-38**** | RAY GWS | Product Announcements | 24 | Oct 25, 2006 11:21 PM |
New Product | GWS-38 (P-38 Lightning)... its here. | Blaze.45 | Hot Online Deals | 18 | Oct 05, 2006 12:39 PM |
