May 20, 2001, 06:42 PM
30 amp power supply
Here's another power supply to consider. It's from Parts Express at www.partsexpress.com . Model #120-555 specs: 30 amp cont, 35 amp surge. 0-15 VDC variable output and it has a current meter and a voltage meter. On sale until 31 May 2001 for $119.80.
The disadvantages of this unit is it's not cheap, but not out of line for 30 amps and it's kind of heavy at 21 lbs.
But the variable output is a big plus. This is equal to 0 to 12 cells,( though I guess anything is equivalent to 0 cells, even no power supply.) Dial in 12 volts for your charger, 3 to 4 volts to break in motors, and if you want to test different props on a motor you don't have to worry about the battery discharging skewing your results.
I'm thinking of getting one but I don't know if I'll get it in time to be able to report back on it before he sale is off.
I hope this helps someone.
Sincrerly
James
Sold Efuel 30 amp 12-18 volt Power Supply Trickycopter Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 21, 2016 10:06 AM
Sold Efuel 12-18 volt 30 amp Power Supply Price Reduc. Trickycopter Aircraft - Electric - Batteries & Chargers (FS/W) 11 Nov 20, 2016 08:44 AM
Sold Brand New Hitec ePowerBox 30 Amp Power Supply LBMiller5 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 20, 2016 09:25 PM
Sold Brand New Hitec ePowerBox 30 Amp Power Supply LBMiller5 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 13, 2016 03:20 PM
Sold Hitec 30 Amp power supply skippykix Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 03, 2016 02:18 PM
