CC HV 85 - Fixed Heli mode, PCM lockout?
Hi,
I think I need to sacrifice a chicken to the heli gods after tonights flying. I changed my E-Raptor to Fixed Heli Throttle mode, setup a 100-80-100 V curve and went out flying. Did a 200+ft tailslide and got a lockout when I tried to flip out of it! Managed to get control back and had probably 2-3 inches left to the ground! The pro's would have been proud ![]() Anyway, Got 2 more glitches while getting back to land, and I NEVER had a lockout on this machine before. After landing I did a range check (didnt do one before I started though) and I got maybe 20 feet away until the failsafe went in. So either antenna is bad (dont look bad though) or fixed heli mode introduced something. Anyone seen this before with fixed mode on the CC HV 85's - Fredrik |
https://www.rcgroups.com/forums/forumdisplay.php?f=168 I always put a ferrite ring on the throttle lead (all ESC’s) just for insurance. ![]() |
Mel,
Is your spool up the same in fixed vs. Gov.? I have a nice spool up in gov w/ the HV85 but when I go to Fixed and switch to Idle 1 it jumps? Sorry to be off topic. |
Ferrite rings are like .99 US so I add em if I have any problems.
If they were a required item all ESC's would have, but few do. Big thing is the heli didn't go in ![]() JM2C. |
No its not, I did a 460 turn when going to idle up, thinking it should be the same (stated in the manual that spoolup speed affected both).. EDIT: I checked my settings, and I had spoolup on 9 (custom) so that can explain it, if you lower it to slow or medium I guess it would work OK. Ive switched to Governor High @ 55% throttle now, gonna see how that compares, if its not good, I'll go back to fixed mode, then I can test around abit. |
An short update.
There was a direct link between range and number of loops in the Ferrite ring. If I added a loop I could go x number of meters extra far away, I ended up with 5 loops (ran out of cable), the range was now 50meters plus (tested in the backyard, didnt have more space) I hope this was the real cause which I experienced yesterday, Wind is to blowing to much for flying atm, will try later tonight and see. |
Thread Tools | |
Similar Threads | |||||
Discussion | WHat is this "Jumper" For in the CC HV 85 Packedge | kushal_22 | High Performance | 11 | Oct 01, 2006 06:45 PM |
Discussion | CC HV 85 - Total reset of settings! | MrMel | Electric Heli Talk | 6 | Aug 20, 2006 07:12 AM |
Discussion | CC HV 85 - Need help! | MrMel | Electric Heli Talk | 15 | Aug 14, 2006 05:31 PM |
Discussion | Figure this out CC HV 85 | callen | Castle Creations | 14 | May 06, 2006 05:45 AM |
Sold | Fs Cc Hv 85 | kushal_22 | Aircraft - Electric - Power Systems (FS/W) | 5 | Nov 25, 2005 02:48 PM |
