Jul 28, 2006, 12:46 PM
sebsoupe's Avatar
depron mini cobra 400
Hello!
I've started to build a depron mini cobra 400 from drawings found on internet...
length : 440mm
wide : 145mm
motor : speed 400 6V (Graupner set #1970)
battery : 6 or 7 cells KAN 950mAh
estimated weight : 500gr
some pictures :
hope it will be a nice boat!!!...
Bye
sebsoupe
Jul 28, 2006, 01:55 PM
Closed Account
Nothing!
Jul 28, 2006, 03:22 PM
sebsoupe's Avatar
Originally Posted by retoabcr
Where do you find info on the depron material.? The posting on the small rigger by RED is made of depron, i'm correct, right. Keep your progress posted for all and let all know how you come out!! Don't forget the info on depron material from a site! Thanks!
Depron is the brand name of extruded foam sheet (polystyrene), you can find it in some building store (3 or 6mm thick for 1,25 x 0,8m)...
http://www.n-schilling.com/scriptsas...pdf_1438.q.pdf
the rigger is made on depron too, you're right.
I'm waiting for the motor at my local store
Then I will keep post on the mini cobra 400 !!!
Bye
sebsoupe
Aug 20, 2006, 04:59 AM
sebsoupe's Avatar
Hello!
just some pictures :
the mini cobra depron is good on water, not very fast but enough for a first boat, and as a friend as built one, we can run together!!!
Buy,
sebsoupe
Aug 20, 2006, 09:18 AM
Closed Account
You did a fine job! Thanks for posting pictures for all to see!!!!
Aug 21, 2006, 02:49 PM
sebsoupe's Avatar
Question, do you put center of gravity at 30%? ?, do you put a skin over depron like 1/64 ply or put finishing epoxy on the outside to seal it/ Those esc connectors, get rid of them, ton of resistance, can cause problems, these are suggestions! You did a fine job! Thanks for posting pictures for all to see!!!!
Yes, CoG is at almost 30%...
I didn't cover the depron, but If I knew how to make epoxy and fiber I would have done it...
The Tamiya connector aren't very good, but I have only that kind on all my models (driving and flying)
Bye
sebsoupe
PS: my friend has built this one :
Aug 21, 2006, 03:04 PM
Closed Account
Both look nice, nice job people. Thanks for replying!
Aug 24, 2006, 02:01 PM
sebsoupe's Avatar
Hello!
I've tried this evening with a 3S lipo : it's Fast & Furious !!!
Bye
Aug 25, 2006, 08:53 AM
soare_geo's Avatar
Hi @sepsoupe. Inspired with you, I create my depron boat. This is in work. Maybe in 2 week finish. I think one brushless motor and LiPo for propulsion.
boat dime. Boat dimension: 48cm x 19 cm x 7cm.
PS excuse my english
Aug 25, 2006, 11:12 AM
sebsoupe's Avatar
Hi!
nice boat!!!
it's a little bigger than mine,
hope it won't be too heavy?...
Bye
Aug 29, 2006, 09:48 AM
soare_geo's Avatar
Hi @sebsoupe, you have a movie with mini Cobra 400? please send me : [email protected]
Thank
PS My dopron boat is in work, mount hardware
Sep 01, 2006, 12:57 PM
sebsoupe's Avatar
a little video (I've paint mine in yellow, the red is at my "boat" friend )
https://www.rcgroups.com/forums/show...72#post6004755
Sep 01, 2006, 11:53 PM
unclecrash's Avatar
Bye
sebsoupe
It is not that hard to fiberglass your little boat. using 30 minute epoxy and some 3/4 ounce fiberglass. You could do the bottom in one piece and the top in another. The 3/4 ounce glass will contour around the radius very well. I use it on my edf jets. You mix the epoxy 50/50 or 60/40 with denatured alchol. this will make a nice thin mixture. Drape a piece of fiberglass over the bottom of the boat and I use a solder flux brush to spread the thinned epoxy. over the glass. brush it out to keep it thin. let it setup for fifteen minutes and put another coat. I use two or three coats to fill the weave just dont let it start to puddle up. If it does you can dab the puddles up with paper towel. For more strength add two or three layers of glass. let it harden and sand. Hope this helps its not hard at all. Then flip the boat sand off the overhanging glass and then do the top. Dave
Sep 02, 2006, 09:24 AM
Closed Account
For my wooden monos (22" ), i use finishing epoxy on the inside and let set for 24 hours and the same for the cobra outside.
Last edited by Mikedown; Sep 03, 2006 at 08:28 AM. Reason: more info to help him out!
Sep 03, 2006, 01:41 AM
TMD
TMD
any chance of getting some plans?
Mini Olympus 400 OK ? nickthefarrow Power Systems 17 Oct 12, 2015 02:17 PM
Video mini cobra 400 depron video sebsoupe Dock Talk 0 Sep 02, 2006 02:27 AM
Depron Mini Rafale gobigdale Foamies (Kits) 49 Sep 24, 2005 01:09 PM
NEW* Mini ZC-400's!!! ZC-50 Gonflyin01 Aircraft - Electric - Airplanes (FS/W) 42 Dec 02, 2002 04:02 PM
Depron ECL SP 400 Combat wing Mike Payne Control Line 3 May 02, 2002 04:04 PM
