Jul 26, 2006, 07:25 PM
Arc, spark and smoke...
desmobob's Avatar
World Models Spitfire EP outrunner and A20-20L
I recently bought a World Models Spitfire EP with their outrunner included. If flies very well with the stock folding prop, CC Phoenix 25 and my 3S 2100mah LiPos.
I had a new Hacker A20-20L laying on the bench the other day when I was checking over the little Spit. Hmm... the World Models outrunner looked exactly the same size as the Hacker. Hmm, again... I wonder if the Hacker would work, and be more efficient? So I swapped 'em.
On the test flight, the Spit seemed to perform about the same; maybe not as well. The battery seemed to weaken early. On landing, I stuck my finger into the cowl to check the Hacker's temp. Ouch! Too hot. I hope I didn't damage it!
What was I thinking? I should have hooked up the watt meter before I even thought about flying it.
Does anyone know any specifics on the little outrunner The World Models supplies with its EP warbirds?
Good flying,
desmobob
Jul 26, 2006, 07:35 PM
ProBro Spaz
spastic's Avatar
what prop?
Jul 26, 2006, 07:52 PM
desmobob's Avatar
Originally Posted by spastic
what prop?
WM mystery prop. Appears to be just over 9 1/2" long, pitch unknown.
The Hacker A20-20L is supposed to spin a 10x4.7 with a 3S LiPo so I figured things would be OK.... guess not!
Good flying,
desmobob
Jul 26, 2006, 09:43 PM
ProBro Spaz
spastic's Avatar
the origional motor is probably a low kv motor, are you sure the diameter is the same? did you compair RPM?
Jul 26, 2006, 11:39 PM
Beijing_eFlyer's Avatar
Hi Desmobob,
The WM outrunner specs can be found in this link
http://www.theworldmodels.com/para/p...M0283010_1.jpg
The folding prop is about 10 x 6
http://www.theworldmodels.com/para/p...id=79&subcat=0
I have a WM Super Chipmunk EP and replaced the stock 480 motor with a KV3600 inrunner mated to stock gearbox. I replaced the folder prop with an 8X6 e-prop and draws 15 amps wot on 8 cell nimh (Kan1050 2/3A).
I'm not familiar with Hacker A20, but you can try a smaller prop. 8X6 should do the job well
Oct 03, 2006, 09:27 PM
desmobob's Avatar
Good flying,
desmobob
To revive this thread....
I flew my World Models Spitfire EP today and stuck my finger up through the bottom cooling vent and touched the stock motor. Ouch! It was plenty hot.... as hot as I remember my Hacker A20-20L being when I tried it in the model.
I'll have to try a smaller prop. I'll have to find a spinner the right size too....
Good flying,
desmobob
New Product World Models: Spitfire EP! gotime242 Electric Warbirds 52 Jun 25, 2010 11:16 AM
Discussion The World Models Spitfire EP desmobob Electric Warbirds 18 Jul 16, 2008 11:09 PM
Sold World Models Spitfire EP The Other Dave Aircraft - Electric - Airplanes (FS/W) 2 Mar 31, 2007 05:29 PM
World Models Funworld EP kmashima Sport Planes 50 Apr 25, 2005 09:24 PM
world models funworld EP 25FX pipe RTF waytoofast Aircraft - Fuel - Airplanes (FS/W) 0 Aug 30, 2004 10:43 AM
