Question
Blade 4in-1 CCPM protection FUSE mod wire gauge
I have my fuses and solder ready to do this MOD but I want to be able to move the FUSE a little away from the motor. If I am correct the FUSE is in between the orangish wire and the motor it self ?
If so I want to be able to run a short wire from the motor's terminal to one end of fuse and then orange wire to other end of fuse. This is so that if I blow one I can pop it off a lot quicker than if it were directly attached to the termminal. There also seems to be some sort of yellow resistor attached to that motor terminal and I dont want to mess with it. OK... here is the question. I am not good with wire gauges. I have some wire from the PSU of a PC/computer. Would that be an ok gauge to use. Or how about the solid core copper wire found in ethernet cables ? |
![]() Put a goodly blob of solder on the underside of the fuse tab, rest it on the terminal, and heat the tab from above, when you feel it "drop," you're done with that side. I do put a little piece of double-sided servo tape between the fuse and motor, this holds it in place while you solder and keeps it from possibly bending down and shorting against the can. That is a capacitor, not a resistor - as long as you don't crush it you can't hurt it really. Last bit, turn the motor so the fuse is at the back -right of the heli, if it's in front it will hit the canopy. |
-Chris |
Well, if you bend the fuse tab at 90 degrees, you actually heat the fuse tab because that's all you can access, so the solder melts long before the motor tab gets hot. A wire off is fine though, it just seems to be more work and once you do it the fuse can flop around.
-Chris |
fuses
JUST FRIED MY FIRST FUSE ! yea , the setup works..........went to radio shack and got the smallest female spade connectors available ( still too big ) and modified them by cutting off one side with the dremmel ... I know I'll be changing fuses every flite session so this should make things easier.........also , by the time I get the solder to stick to the fuse ( slag metal ) ( on the mini fuses ) they sort of melt....didn't check to see if it affected the performance.........be sure to use shrink wrap and double sided tape to anchor it..........SCOTT RULES...........gravy
OMG ! barely 45 mins after installing the fuse I got to see it work. Picked up the heli after a CFIT and tripped the idle-up switch by mistake. One nice red welt on my arm later I noticed the gap in the fuse where the wire had melted and my motor would not crank. Just fixed it in 2 mins,
Scott you the man. Now how hard could it have been for Horizon to implement this in their design. Sheesh. ! |
Thread Tools | |
Similar Threads | |||||
Question | Wire Gauge/Fuse Questions | kagreen2k | Micro Helis | 10 | Jun 26, 2004 04:32 PM |
Music wire gauge conversion | lumins | Power Systems | 3 | Jan 13, 2002 05:14 PM | |
35-ish Amp System - Sermos OK? What Wire Gauge? | Mitch G | Power Systems | 3 | Jul 19, 2001 09:07 AM | |
Wire gauge??? | planecrash | Electric Plane Talk | 3 | May 09, 2001 04:35 PM | |
Battery Pack Wire Gauge? | LJH | Power Systems | 8 | Apr 23, 2001 12:55 AM |
