Jul 31, 2002, 06:51 PM
Sylvain's Avatar
Corona/LMH main blade balancing tape
Hi,
I have always used electrical tape to balance the main rotor blades of my LMH . But it doesn't stick very well. I need to replace the tape every 3 weeks. I'm looking for a better tape. What kind of tape are you using to balance your blade? (I bought it used that's why I don't know what is the original balancing tape)
Also, are you balancing the tail rotor blades using the same tape?
Thanks...........Sylvain
Jul 31, 2002, 08:51 PM
I use electrical tape on mine and I haven't had to replace it yet.
I think your tape is old, and has lost much of its stickiness. You might try buying a new roll of electrical tape.
Toshi
Aug 01, 2002, 07:29 AM
Sylvain's Avatar
and what about the tail rotor blades balancing?
Sylvain
Aug 01, 2002, 10:18 AM
toddp's Avatar
Monokote Trim Sheets
The tape that comes with the corona is very similar to, or maybe is monokote trim sheets. You should be able to get these at any r/c shop in many colors.
Aug 01, 2002, 04:57 PM
I ment to do that!
acr1346's Avatar
Make life easy, use the heat shrink you cover your battery packs
with. It never comes off. Slice to fit, trim as required to balance, heat (doesn't change the weight) fly!
