Swift II
Thought you guys would like to see this. This is my swift and did a batt cover for it. I have had this wing for a while and hated the way it flys. But Giggs helped me put a different motor on it and change the battier on it and now I think it is a keeper. I had to big of a motor on it and the battier also. So it did not fly well at all. Describing it as a swift on crack would be the good term for it. But Diggs and I took it and tried it out this evening and things went well. I made a cover for the batt slot to keep it neat and it turned out ok I think.
Thats it for now. More Trim |
Cheep CG tool
This is a good thing to have in the shop. I made it out of some scrap mdf board I had. I put some Velcro on the base and the rods to make it easy for storage.
So for anyone that needs a cg tool here ya go, easy to make and it works great |
Just move deliberately and cautiously! See if you can probe each cell's negative and positive tab individually? |
Hey guys,
I just recently obtained a Swift II and thought I would share my setup. HobbyCity 1700kv brushless motor- http://www.hobbycity.com/hobbycity/s...idProduct=5208 10A generic ESC 7x6 HD GWS prop x2 HS-55 servos Outrage 3S 450mah 25C lipo GWS 4ch RX The RTF weight with this setup is around 8.6oz. To get the proper C.G. I had to add a slight amount of nose weight (> 15 grams) in the form of screws. I believe the C.G. is spot on as it doesn't pull or push during the dive test. It also glides very, very well. The power to weight ratio is insane, at 3/4 throttle the Swift will do unlimited vertical and at full throttle... I have yet to put it on my watt meter but I know it's drawing less than 10 amps. After a 10 min. flight with constant throttle usage the battery and ESC are only slightly warm, the motor is cool to the touch. The only thing I'm going to change in the future is the lipos. I'm looking at something like a 3S 20C 610mah so I can remove the nose weight. I am extremely happy with this power setup and would recommend it to anyone |
I bought a few of them on a recommendation, and I gotta say.... those motors are a freak of nature. |
Yea you can do so. It is possible to do it. I need to figger out how to do the same thing. Diggs has a batt he wants to do the same thing with. I need to ask him if he has figgered it out. And I can give you some enfo on it.
sounds kewl I am searching the web not finding much. I will share if I find anything also.
boB |
More trim,
what size bat is in that plane in your pics? I might start all over with mine. I tend to way over build I have 2 CF rods. lots of protective tape( thank God I had it because i needed it) |
I am using a Rhino 610 20c 3cell on it. And it dose just fine. Very lite. You can get them at Hobby City for cheep.
I have a 800 3s on its way. I hope that will lighten my load. Im using a 25c 1500 now
Thread Tools | |
Similar Threads | |||||
Discussion | Good setup for a MSComposit Swift II ? | myrslakt | Foamies (Kits) | 4 | Oct 10, 2009 02:30 PM |
Video | Swift II Maiden | Sim69 | Electric Plane Talk | 3 | Jan 28, 2007 12:32 AM |
Sold | Swift II Airbrush line British Scheme | Twinkletoze | Aircraft - Electric - Airplanes (FS/W) | 0 | Jan 05, 2007 11:58 PM |
Discussion | Swift II from MS Composit? | db1 | Flying Wings | 14 | Dec 11, 2006 08:13 PM |
Discussion | My Swift II + Question | highboy | Flying Wings | 2 | Nov 29, 2006 12:05 PM |
