Jun 28, 2006, 09:50 PM
Question
Tips for new wing to old fuselage?
I've bagged a new wing and want to attach it to a fuselage that already has the holes drilled and tapped from the previous wing. How do I do it?
I've read a long time ago about a technique where steel screws (same size as the wing hold-down screws) have the heads cut off and the tops are shaped into a point. These modified screws are then screwed into the existing holes, then the wing is gently pressed down on top of the pointed screws so that a depression is made into the wing. Then the holes can be drilled out using the depressions as a reference.
Do I have all the steps correct? Is there a better technique?
What are your thoughts?
Please let me know...
Thanks!!
Eric
Jun 29, 2006, 09:24 AM
Eric, That is basically the way I do it. The only difference is that I use nylon bolts sharpened to a point. Make sure you spend some time getting the wing square to the fuse and level to the tails. Good Luck.
Scott
Jun 29, 2006, 12:49 PM
TROUT OR THERMALS
steelhead's Avatar
I second the nylon bolt method. Easy to sharpen.
Tape the new wing down really well, and give a turn or two slowly to get a good location marked. The twisting will really show the center of the hole.
Dean
Time for a new wing. Ideas please... cactus Flying Wings 16 May 31, 2006 03:02 AM
What dihedral for new wing by Steelhead? Daddy-O Aerial Photography 12 Mar 06, 2005 08:41 PM
RIP Zagi...Time for a new wing! MrBlenny Slope Soaring 6 Mar 03, 2005 10:28 PM
Any Tips for a new flyer? haddorh Micro Helis 6 Jan 23, 2005 03:11 AM
Tips for strengthening the wing of the Hobby Lobby Eric Shiver Electric Sailplanes 2 Jul 08, 2001 09:28 AM
