Jun 28, 2006, 04:32 PM
OS FL 70 4-stroke Prop size
It is running a 12-7 at the moment. I think i would be interested in a 13-4 or even a 14-4 for more climbing power. How do you think this 4-stroke would do on a 13 or 14 incher.
Jun 28, 2006, 06:17 PM
Ascended Master
Sparky Paul's Avatar
The Kadet Team uses thd APC 14x5N almost exclusively on our OS 70 4-strokes.
With a 13x6 as backup.
Jun 28, 2006, 08:16 PM
So what is better
APC 14-5 or APC 14-4
I want good vertical performance
Jun 28, 2006, 09:03 PM
Ascended Master
You have to match your prop to your airplane and motor.
It can't be done without flying it.
Jun 28, 2006, 10:41 PM
Thanks, i think i will try the 14-5 first.
I am a little worried about over heating and bogging the engine down. Do you see this effect with your engines.
Jun 29, 2006, 10:55 AM
Ascended Master
The 14x5N seems to have been made for the OS 70.
Why the prop even exists is a mystery, but it -is- the prop for that motor on most planes.
It is also -expen$ive-... once the tips get ground down, the performance drops noticeably.
Jun 29, 2006, 11:32 AM
It is kind of expensive
How do you think woods would work. The ones i am using now are wood but they do seem heavier
Jul 03, 2006, 04:47 PM
14x5N is a pattern prop. I have heard that they are widely used in Japan with ys-63 engines. They are pricy and they come with 8mm hole if I remember right(saw these on the field). Wasnt fl-70 shaft smth like 6.5mm?
Jul 04, 2006, 10:52 PM
I did notice that Kema. I decided to try the apc 13-6 prop instead.
Jul 09, 2006, 10:17 AM
Hi guys, i tried a 13-6 with great results.
The idle is alot nicer
Jul 09, 2006, 10:30 AM
Ascended Master
I haven't had to shim the APC 14x5N to fit the OS 70 shaft, which is 5/16"-M4, according to the manual.. It's been so long since I've had to change a prop on any of mine I don't recall if the prop needs to be reamed.
Jul 09, 2006, 02:33 PM
i have the FL 70 though, not the FS
Jul 09, 2006, 03:52 PM
The sky is my playground.
Dora Nine's Avatar
I'm using a 12X7....been thinking of a 13X6...the plane's about 7 pounds....decent vertical....but nothing spectalcular...
Jul 10, 2006, 10:18 AM
S.A.D. member
ivanc's Avatar
Go for the 13x6 prop - you will notice some difference!
ivan
Jul 26, 2006, 09:35 AM
ProBro Spaz
spastic's Avatar
a great prop for that size 4stroke is the MAS Scimitar 13x6 nylon or wood and they are cheaper than the APC's the nylon one will last for a long time its very durable..
they have more bite than the 13x6 APC
For Sale os FL 70 4-stroke Cambo Aircraft - General - Miscellaneous (FS/W) 0 May 16, 2007 05:49 PM
Sold OS 70 4 stroke Eagles4lee Aircraft - Fuel - Engines and Accessories (FS/W) 4 May 11, 2006 11:56 PM
Found OS 52-70 4 stroke(s) Or similar...I NEED 2 Kev71H Aircraft - Fuel - Engines and Accessories (FS/W) 4 Feb 27, 2006 10:53 PM
Prop help on a .70 4 stroke please? Handy Engines 8 Nov 11, 2005 02:43 PM
OS .91 surpass 4 stroke with mount, fuel filter, tank, prop, spinner Steve H. Aircraft - Fuel - Airplanes (FS/W) 2 Jul 01, 2004 09:01 PM
