Electric Easy Glider Upgrade - RC Groups
Jun 17, 2006, 10:42 AM
Donald Duck's Avatar
I want to put a brushless in my Electric EZ Glider when the 400 goes out. Is there an easy "drop-in" replacement that will fit the gearbox and the nose of the EZ Glider? What is the ratio of the gearbox that comes with the stock 400 in the Electric EZ Glider? Any guidance will be appreciated.
Jun 20, 2006, 04:23 PM
Hitec/Multiplex USA
MikeMayberry's Avatar
Part# 992451 is the complete system with BL-400 6D/ 27A ESC, new gears, locktite and lube.
http://www.multiplexusa.com/models/P...asyGliderE.htm
Mike.
Jun 25, 2006, 07:49 PM
Mike.
Yes, but when will they actually be available? I have had one on order from Hobby-Horse for 2 months and am still waiting. Every time I call them they say it should be about 2 weeks.
Tom Moody
Jun 26, 2006, 04:45 PM
Hitec/Multiplex USA
It seems we are waiting on the locktite and lube to complete the combo... everything is still available separately. Or you can get the 10 tooth pinion for the Showgun from Hobby People and use the stock output gear and keep the 3-1 gear ratio.
One of the guys here did this and with the 6D motor on the stock prop with 3S Lipo he was torque rolling it!
Mike.
Jun 26, 2006, 10:15 PM
mem
mem
mem's Avatar
Or you can get the 10 tooth pinion for the Showgun from Hobby People Mike.
There are two Shogun 10t pinions on this page:
http://www.hobbypeople.net/guru/hps_961833603.asp
Do you recommend this one?
2.3mm diameter http://www.hobbypeople.net/guru/hps_961833568.asp
or this?
2.31 diameter: http://www.hobbypeople.net/gallery/165339.asp
Michael
Jul 11, 2006, 12:58 PM
Hitec/Multiplex USA
Neither... 3.17mm http://www.hobbypeople.net/gallery/165340.asp#More
Mike.
Jul 11, 2006, 04:01 PM
mem
mem
mem's Avatar
Michael
Nov 21, 2017, 03:46 PM
What goes up ...
Multiplex brushless motor and gearbox Lube & Locktite
Hi Everybody,
A great brushless motor for an 'older' version of the Easy Glider was (and still is) the Multiplex Permax BL-400/8D-3.2. That motor is used with a good propeller via a motor shaft gear (attached with Locktite 638) and a gearbox. If the gearbox has been well cleaned and now it should be re-lubed, could you confirm the type of lube that was previously included in the brushless motor upgrade kit?
The Multiplex box part was M992541 Upgrade Kit. The brushless motor was (is) a Multiplex Permax BL-400/8D-3.2. The Lube & Loctite was part # 33 2469. The Loctite in this package was (is) the Locktite 638 shown in the attached photo, but what was the lube product name and where could that still be purchased?
Could you also post a copy of the past instructions that are also shown in the attached brushless motor upgrade kit photo?
Is the lube maybe a white lithium grease?
(The attached photos were previously shown in https://www.rcgroups.com/forums/show...r#post33765735 )
https://static.rcgroups.net/forums/a...4-IMG_1115.jpg
https://static.rcgroups.net/forums/a...9-IMG_1116.jpg
Any advice you can provide would be greatly appreciated ...
Cheers,
Dave
Discussion Aileron Servos for Electric Easy Glider skyhawk1 Foamies (Kits) 2 Jul 10, 2007 12:04 PM
For Sale Easy Glider Electric - Brushless Upgrade HCDLC Aircraft - Sailplanes (FS/W) 3 May 13, 2007 01:29 AM
Discussion Multiplex Electric Easy Glider Hard Wiggles Electric Sailplanes 2 Feb 24, 2006 01:00 PM
