Jun 12, 2006, 09:07 AM
Herky-Bird's Avatar
Thoughts on an unusual Logo 10 Power Train...
I'm picking up a second hand Logo 10 and I want to use the power train I already have around from a plane. I'm only looking for sport flying as I'm still learning but having failed to get my head around KC's spreadsheet, could anyone give a 'lay persons' opinion on this set-up please?
Many thanks
Grant
Motor
MaxCim MaxN32-13y
1420 Kv
0.8 Lo
58 Rm
213g weight
Esc
Maxµ35D-21
9 Resistance
35 Avg Current
65 Max Current
21 Cells
85g weight
Battery
6s1p 3300 Flightpower Evo20
Weight 560g
Internal Resistanec not known.
Jun 12, 2006, 10:26 PM
I'm currently using a Himax motor with a 1000Kv rating on 6 cells with 16
tooth pinion. I've also used a airplane outrunner with good results.
For general flying my average amp draw is 16 to 17 with peaks to 23.
Average Power is 375 Watts with peaks to 500.
Head speed around 1700 depending on batt voltage.
Ron
Jun 12, 2006, 10:38 PM
Destroyer of G-10
askman's Avatar
with 58mohm Rm, it will bog a lot. but will work if you keep the head speed reasonable. marginal sized motor, so keep an eye on the heat.
Thoughts on an new foamie trainer kestrel2003 Foamies (Kits) 4 Feb 10, 2005 03:10 AM
Logo 10 Power System Problem DerrykDavis Electric Heli Talk 13 Dec 17, 2003 09:47 AM
Bandit on an AXI 2820/10 soholingo Electric Sailplanes 39 Jun 06, 2003 12:20 PM
