Jun 01, 2006, 07:01 PM
aerohydro's Avatar
Does anyone build stuff like this anymore?
I've come back to micro building after about a year doing other things and have noticed a shift in the focus of most threads here. When I last checked here there was an abundance of threads detailing simple and cheap balsa, tissue, cling wrap and foam airframes, with bitcar radios, N20s, 6mm pagers and the like. Now most posts seem to be about people doing interesting things with aeroace clones and very highly detailed, fanatically lightweight models. Of course this is not a bad thing, but I'm wondering if people are still doing this old fashioned stuff as well?
What is everyone up to?
Jun 01, 2006, 07:11 PM
billystiltner's Avatar
Hey
Nice plane. Details please.
I was just thinking of making a big living room flyer.
I have went as small as I can go with current equipment and thinking how easy it would be to go back and build a room flyer with 6mm motor.
Billy
Jun 01, 2006, 08:50 PM
aerohydro's Avatar
Balsa fuselage, wing and tail structure with thin shopping bag covering.
1mm carbon wing pylons and landing gear
650mm wingspan, 200mm chord, 500mm long overall
Bitcar radio with mosfet modification, 140mah lipo, N20 direct driving a U80 prop
Weighs 19g, too heavy for lrf for me.
This is really just one of my many variations on a theme inspired by Greg's flamingo, nothing too exciting. I've been having fun flying it in the updraft from my chimney.
Leon.
Jun 01, 2006, 09:31 PM
dhurd's Avatar
Dave Robelen just posted this plane over in the smallrc forums.
http://www.smallrc.com/forum/showthread.php?t=426
Jun 01, 2006, 11:04 PM
FFFlier's Avatar
I've got a cheap 10" foam plate/bamboo stick bitglider that I winch up to about 60-80' using a radio shack motor and thread. Just did the 9v mod and will try to double the height and hopefully the 40-45 second glide times. I'm using 1-2 2016 lithium coin cells on the rx which work great with my bird actuator. My free flight models take a lot of adjustments to launch straight but with rudder control, they go straight up right away!
Also tested out a bit rx on 2 2016 cells on a 2.25" muscle wire rudder actuator which wiggled back and forth very well. (mw breaks a lot with handling though) (Was trying to make propo rudder before AeroAces came
out).
I think we have to post bitmodels in the parkflyer/foamies forum now.
Bill
Jun 02, 2006, 12:41 AM
Ol' Deadeye
Dusty Puddles's Avatar
Looks like I'm trying the same stuff as you Aerohydro. This is my latest LR. I call it a LR because to be a LRF it would have to fly sucessfully. At the time I didnt have any light balsa an it ended up weighing 14.9 grams. With 60 inches I fear it won't fly slow enough.
I've got some better balsa now and plenty of CF rods so I'm thinking of entering the LRF cookup. Ought to be fun and informative.
Jun 02, 2006, 02:22 AM
RC-Kraut
relaxr's Avatar
Those are shurely not out of time - if consquently light, they are so slow that you can follow them with the Tx . And there should be no damage on them if going down. But for both planes shown here, the tail areas look (imho) a bit short. That could make them tipstallers or spiralers
Bye
Jun 02, 2006, 04:47 AM
aerohydro's Avatar
DRETWR, Nice model, though I agree you would probably need a fairly large LR at that weight. Mine is a different animal however. I get reasonably slow flight with plenty of power and wing incidence. Flys comfortably in an area about 7 x 10 metres. A large rudder with lots of throw makes control very responsive.
relaxr, tail moment is indeed short but area is reasonable. I have never had a problem with tip stalling. This may be due to the way my wing is rigged: threads tie the front spar to the fuselage, but the rear spar is unsupported. This allows the trailing edge to lift at the wing tips, reducing angle of attack.
It's really amazing the sort of poor construction, shoddy repair and abuse these planes can take and continue to fly. I once had the complete outer wing section removed by a tree, yet the model was still controllable, did pull to one side a tad.
Jun 02, 2006, 06:16 AM
gbarc's Avatar
Yeppers people still build planes using Bit Rx/Tx's! In fact i build them all the time. Glad to see people are still building variants of my Flamingo.
Greg
Jun 02, 2006, 09:15 AM
Ol' Deadeye
Aerohydro, after I posted I started converting metric to inches, oops.
Mine is 4 grams lighter.
Yours is OVER THREE TIMES LARGER, WOW!
Different animals, most certainly different breeds.
Back to the board.
Ted
does anyone have information about this model? Bob Chiang DLG Hand Launch Gliders & F3K 3 Jul 12, 2002 03:19 PM
Does everyboby know someone like this? Another David Electric Plane Talk 29 Jun 06, 2002 12:10 PM
Would you build a wing like this one? RookieOne Electric Plane Talk 12 Feb 18, 2002 10:22 AM
Does anyone know anything about this wing? jdpowell22 Electric Plane Talk 2 Jan 25, 2002 01:05 PM
Does anyone know anything about this possible virus?? Jeff Meyers Life, The Universe, and Politics 15 Jun 04, 2001 06:32 AM
