May 22, 2006, 03:23 PM
ZOB
ZOB
kA3 1/2 SCALE
Hi all, well I've not done this before so here goes. I started this project 2 1/2 years ago and it has been on and off eversince, I enjoy building and the challanges it brings. This model is based on a plan drawn by Cliff Charlsworth but beefed up and modified as required. As luck would have it where I work here at RAF Cranwell the Gliding club has a K3 in the hanger so I could visit as and when I wanted .
May 22, 2006, 03:51 PM
ZOB
ZOB
The tail section has wrapped round leading edges on the ruddervators with the tailplane being sheeted with 3/32 ply, the hinges are silver steel pins and drilled and splitpinned.
May 22, 2006, 03:57 PM
Support www.usf3jteam.com
little flyer's Avatar
One word. WOW.
May 22, 2006, 05:33 PM
TEAM GORGEOUS
SZD16's Avatar
Originally Posted by little flyer
One word. WOW.
I'll second that! WOW!! Can't wait to see the rest......
May 23, 2006, 01:43 AM
Vini, Vidi, Scalies
LoopingFred's Avatar
Wow Zob, as I already said, very very impressive !
Do you have more pictures of the real one ?
I cannot find enough documentation for this glider, other than what I've found in the scale soaring U.K website...
Fred
May 23, 2006, 02:56 PM
What servos did you use on this?
Alistair
May 23, 2006, 03:11 PM
Use a camcorder to get the cg, Great footage!
May 23, 2006, 03:29 PM
ZOB
ZOB
Alistair
Hello Alistair, the servos are as follows 4xHitech HS755 HB 1/4 scale, one on each flying surface, 2x Futaba on the spoilers and 1 futaba 3001 on the Tow release I have also used a battery backer, Opto isolator,2x Flight packs 2000mh and 1 reciver pack 1100mh.
ZOB
May 23, 2006, 07:40 PM
TEAM GORGEOUS
SZD16's Avatar
Originally Posted by ZOB
Ok guys, I weighed the finished model today and it came out at 40lbs which I am happy with. and I have balanced the model at 25% of the cord to start with.
Very impressive! I can just imagine what everyone had to say when it was assembled on the deck for the first time!! 40lbs might not be enough, you may need to add some ballast to get it to penetrate.......you'll know after that first flight ....25% is very conservitive on the CG....a good place to start.....I would guess that after you have flown it for awhile that will move back.....I started with 33% on my SZD-16 https://www.rcgroups.com/forums/show...4&page=8&pp=15
and will be taking some out the next time I fly. Keep us posted as to the first flight......
May 24, 2006, 01:26 AM
Vini, Vidi, Scalies
Fred i will put some photos on your thread of the real glider. Hope you like the next set of pictures.
Thanks a million for the pictures Zob !
And about the new set of pictures... Well... I'm still on my knees, crying...
Very beautifull piece of craftmanship here !
Fred
May 24, 2006, 03:19 PM
MTT
MTT
I care about rising air !
MTT's Avatar
Taken in the Hanger were i work that is a Dominie you can see
A Dominie is the Hawker business jet, right ? HS-125, I believe ?
Michael
May 24, 2006, 03:25 PM
ZOB
ZOB
Michael
Yes michael the Dominie is the RAF version of the HS125 they use them to train aircrew I am an aircraft fitter and service them for the RAF.
May 24, 2006, 03:59 PM
MTT
MTT
MTT's Avatar
I was just asking out of curiosity....
I worked in general aviation maintenance for a long time, worked on almost everything from single engine Cessnas to Citations, Lear Jets, King Airs, etc.
Never got my hands on a Hawker, though.....
By the looks of the exhaust of the engine, your Dominie is the older version, with the GE CJ-610 turbojet ( no fan) engine.
We used to call them fuel-to-noise converters....
1/2 scale FF WINGO!! Summer Foamies (Kits) 39 Nov 11, 2004 10:40 PM
1/2 Scale Bike meangreenie Motorcycles 4 Jan 11, 2004 07:08 AM
Maidenflight 13m ASW22 (1/2 scale) FlyingFlorry Slope 14 Nov 08, 2003 06:38 PM
1/2 Scale Air-Bike Ultralight bobandris Scale Kit/Scratch Built 6 Aug 27, 2003 09:11 AM
Bluecor 1/2 Scale Kadet Seniorita Matt Chester Foamies (Kits) 15 Feb 28, 2003 11:21 PM
