View Poll Results: EDF Harrier.... Can it be done
Yes... and soon! 491 69.94%
Yes... In 3 years. 134 19.09%
Yes... In 10 years. 42 5.98%
No way! 17 2.42%
Only NASA can pull that one off! 18 2.56%
Voters: 702. You may not vote on this poll
Sep 24, 2021, 05:18 PM
You can probably close the cockpit and open another cheater hole from the front landing gear bay
Sep 26, 2021, 12:14 PM
maybe that is an great idea too...unfortuantly there is no other way in this harrier project, i need those edf.. i have treid to take off without any additional edf succesfully but it resulted in weak pitch momentum. i increased the bleeding air channels but that gave alot of thrust loss, 160 amps during hover without a harrier body. Those 2 little edf helps with T-Vector, and reduce the amps to 75A . lets see in the coming 2 weeks
RC Harrier AMAZING! First Flight Without Additional EDF!!VTOL F-35 video soon again;) (2 min 59 sec)
Oct 01, 2021, 04:32 PM
buildupdate
weight including lipos, landing gear ect 6,2 KG....still too heavy but we should have 10kg trust...lets see........
Oct 01, 2021, 04:43 PM
Looks amazing, such a unique shilouette on that plane. Fingers crossed for the test flights!!
Sent from my SM-G970F using Tapatalk
Oct 01, 2021, 04:53 PM
Purdue Engineering
Rocketman1092's Avatar
Wow, looking great! Really impressive to be able to design and print a whole airframe in such a short period of time. And with panel lines even!
Oct 02, 2021, 12:09 AM
Itís fantastic!!
And 6,2kg is a great result considering the whole list of parts..
Are lipos 12S 5000mah?
Oct 02, 2021, 11:00 AM
Originally Posted by raddrilene
Itís fantastic!!
yes 70C
Oct 02, 2021, 11:02 AM
Harrier Joel Vlashof
I'm so happy, weight without lipos 4 kg exact...amazing. watching this model for the last hour now:P Today i installed side wheels, rudder and flaps. tomorrow i will add the ailrons and wiring all together to the KK2.1 board
Oct 09, 2021, 11:29 PM
Awesome got the first hops:P 6,2 kg 12s 4000 and 3s 4300 for the small edf units. from now on alot of tuning
First Vertical Hops | RC Harrier Vtol Model | 1/7th scale #short video (0 min 24 sec)
Oct 10, 2021, 06:29 AM
Harrier Joel Backyard testing
Tuning this complete build model is difficult!! i used to tune a simple testframe and settings are easy like an drone, now i have to fight the mass of this bird
Oct 11, 2021, 05:28 AM
It is moving slower but basics are same. More gain until it oscillate. If you not reach oscillation then you have not enough control power.
Oct 16, 2021, 12:07 AM
Exactly, i have reached occilations, tuned it back but than i had less controll going to put bigger edf in nose and tail for better momentum in pitch and yaw
Oct 16, 2021, 12:08 AM
Lets try it out
Oct 16, 2021, 07:05 AM
Harrier RC VTOL Model, First Test Flight Ouside (2 min 11 sec)
Discussion Moved - Thoughts / Ideas for a Harrier - VTOL. What do you think? FirmamentFX Fuel Jet Talk 5 Nov 30, 2009 12:28 AM
Discussion Thoughts / Ideas for a Harrier - VTOL. What do you think? FirmamentFX VTOLs 16 Oct 13, 2006 04:49 PM
