only on top
the swift 2 is definitly not fast but it is quick. With the setups on ours we get probably 60mph and unlimited vertical, as well as slow as you can go speed. I have a ms 300/34 and its a little slower than the other ones I have built but I am only pulling 11amps and the others are pulling around 16. I get 15min plus flight times and the others get around 7-12 min flights on 1000mah batts
Not trying to be rude, but the Swift II thread is here.
https://www.rcgroups.com/forums/showthread.php?t=540977 I am sure you will get a lot more responses there. Diggs |
wow...so apparently i needed 2 3s 2200mah batts at 376 grams to balance!
wow... i read about how it needs alot of weight, but its crazy... does that sound right to anyone? |
I am using a 3S 3600mah and it balances pretty good. But it pulls up in a dive test indicating it is nose heavy. Not sure of the weight of my lipo, but it is a big old polyRC pack. I think 2 2200's would be too much unless you mounted a big heavy motor on the rear.
Diggs |
it definatly has a huge motor... large enough that it wouldn't fit the stock motor mount, and i had to make my own out of plywood.
Right at 320mm back is the balance point. Emax 2810/12 |
Yeah, it's hard to reconcile adding all the extra weight just to get it to balance. I struggled with that issue as well.
To quote me (post #64); Quote:
Thread Tools | |
Similar Threads | |||||
Discussion | MS Composit Maxi Swift | tioli | Flying Wings | 7 | Sep 17, 2009 05:01 PM |
Discussion | MS Composit Mini Swift | tioli | Flying Wings | 19 | Jun 01, 2009 09:13 PM |
MS Composit SWIFT Building and flying thread! | gbagley | Foamies (Kits) | 20 | Jul 30, 2004 01:48 AM | |
MS Composit SWIFT Delta Wing | bobf | Foamies (Kits) | 25 | Jun 30, 2003 06:47 AM | |
MS Composit Swift - PAINTING? | Helicool | Foamies (Kits) | 4 | Dec 30, 2002 08:38 PM |
