May 09, 2006, 10:11 AM
Guy Griffin
Guy Griffin
Guest
Dremel spindle thread size
Hi,
Does anyone have a Dremel multitool, and could they tell me the
length/diameter/pitch of the spindle thread? It may be imperial as these
things are American, and around 7mm/0.275" dia.
Reason is, I found a little dremel 3-pin chuck - just right for a
high-speed drill, except the thread in the back is obscured by a central
pin and not accessible to measure.
cheers
Guy
May 09, 2006, 12:11 PM
Peter Fairbrother
Peter Fairbrother
Guest
Re: Dremel spindle thread size
Guy Griffin wrote:
> Hi,
I haven't got an actual Dremel, but I have three dremel-type tools - the
collet chucks on all three have M8 x 0.8 threads (even though the collets
are not interchangeable - some are longer than others).
HTH
Peter Fairbrother
Tim Auton
Tim Auton
Guest
My RotoCraft tool has metric threads too. The tools don't fit my
Dremel Professional. Nor does my metric thread pitch gauge. And I
couldn't find my imperial gauge. Quick and dirty (calipers and
counting) measurements of the Dremel spindle are:
OD 7.2mm (9/32"?)
Pitch around 0.63mm (40tpi?)
The spindle has just under 12mm threaded, and 2mm unthreaded (at the
end you hold). With a Dremel chuck fully screwed on there is 2mm of
thread still showing.
Tim
Did I really still have that sig?
May 09, 2006, 04:11 PM
Guy Griffin
Guy Griffin
Guest
> OD 7.2mm (9/32"?)
Thanks Tim, much appreciated. A bit more web searching in various (US)
forums suggests most people clock it as .275" x 40tpi, so 9/32" (without
clearance) seems very likely.
I'm not surprised oriental copy tools aren't interchangeable, they seem
to prefer metric!
cheers
Guy
May 09, 2006, 08:11 PM
> cheers
> Guy
Workshop Practice Series No. 27 "Spndles" by Harprit Sandhu gives the following
dimensions for the Dremel Thread - 0.277" x 40 TPI
On pages 132/133 drawings for the spindle, collet & cap
Regards
Brian
hs-81mg thread size for servo horn whirlyspud Electric Plane Talk 3 Aug 29, 2003 08:17 AM
IPD/EPS prop shaft thread size? ScienceGuy Power Systems 3 Aug 29, 2003 06:15 AM
Thread size of GWS shaft? akh223 Parkflyers 1 Apr 02, 2003 12:02 AM
Thread size for Mini Piper wing bolt? Jeff Kelety Parkflyers 2 Jan 05, 2003 11:38 AM
6v 400 mounting hole thread size Al P Electric Plane Talk 16 Jun 06, 2001 12:25 AM
