Apr 21, 2006, 12:12 AM
dougmontgomery's Avatar
New Product
New Designs- Laser cut Motor mounts for flatplate planes and Wings
I should have everything available on my site by Mid May. Any comments are welcome.
Rich at GundersonAeroDesign helped to expedite my order and has great customer service.
The top Mount/Skeg is for a edp50XC on my 5.1 oz Slo-wyte.
To accomodate Himax or eflite outrunners 370 to 400, or CustomCDR Delta mount.
Wing Mount, Designed to be installed as a pusher before or after the fact, just cut in a slot 6.3 mm wide at rear and Epoxy into airfoiled wing.
Middle mount to attach to a flat plate plane with no vertical fin.
Removable "+Mount" designed to slide onto rear of flat plate pusher and be screwed on. Will accomodate Brushed 300-350, Outrunner 370 or 400, Custom Cdr Delta mount brushless- 370-400 inrunner zip tied to top.
Control Horns,3 position- Designed for 6MM depron and has a lock plate on bottom.
CustomCdr Delta base Motor Mount-Designe specifically for: WWW.CustomCDR.com
Thanks for your support in advance, My Website is currently being built-This on is generic.
Doug
www.Montgomeryliteflyers.com
Apr 21, 2006, 10:02 AM
Krued Up
snolord1's Avatar
i definately will need a few of these.
Motor mounts for X-fuse planes available... Goge Foamies (Kits) 0 Oct 17, 2004 12:33 AM
Motor mounts for X-fuse planes available... Goge 3D Flying 0 Oct 17, 2004 12:30 AM
FS: Laser cut motor mounts, control horns, servo trays ClosetRCModeler Aircraft - Electric - Airplanes (FS/W) 0 Apr 21, 2004 05:01 PM
NEW laser cut A 10 nacelles for 90mm fans Tristar500 Electric Ducted Fan Jet Talk 19 Mar 17, 2004 07:48 PM
Have you used the Laser cut strut set for TM SpaKack Parkflyers 1 Apr 14, 2002 08:39 AM
