Apr 10, 2006, 10:45 AM
New Product
Vision Hobbies Annouces the MDrive ESCs and Poly RC Lipos
Motortron MDrive™ Brushless Speed Controllers availble from Vision Hobbies !
-Simply the Best on the Market
-Store 3 Different User Modes and or Models on one MDrive ESC.
-Operate and tune your motor from your PC via a graphical user interface!
Motortron MDrive Electronic Speed Controllers from Vision Hobbies use a very sophisticated algorithm software for sensorless brushless DC motors which, allows the motor start up or slow down at very low RPM with no jittering or grinding often found in other ESC.
MDrive ESC makes available motor efficiency all the way through the motors powerband with no limitations at the top-end of your throttle. The difference is immediately noticeable. The throttle control vs. motor RPM is completely proportional and is tuned to your transmitter for full range of motion on your stick.
Each of the components on the ESC has been tested for its maximum ratings and reliability. And if something does go wrong, customer service is priority.
You can select Plug-n-Fly or define your exact motor specifications for optimum performance! With the free downloadable Motortron ESC-View software and free PC interface cable included with your ESC purchase, you can run and fine tune your motor to optimum performance.
Using your PC as a throttle, you can record different settings, try different props, battery cells and review for best performance before your fly! Change props and watch how the information is visually shown in real-time graphics.
No more fly and test, fine-tune your changes as necessary for most favorable operation before you fly! It's like having your own personal Dyno-Meter for your brushless motor!
There is no substitute for the quality, performance and value in the MDrive™ controllers. ESC-View Software is available by simple download or direct from Vision Hobbies.
Also don't forget to check out our new Poly RC Lipos! These cells use the top-of-the-line Enerland cells providing 20c and 30c BURSTS! All products are in stock from 300 mAh to 7400 mAh 5s2p!
Thank you for your time and support.
www.visionhobbies.com
sales@visionhobbies.com
Jun 28, 2006, 08:44 PM
Just got an Mdrive from Visionhobbies. Nice product, good service.
Whoesale Source for Poly Quest LiPos Flyguy55 Batteries and Chargers 1 Aug 12, 2005 11:29 PM
Poly-Quest Lipos And PCM Charge Guard Needed Or Not? Joe Elston Batteries and Chargers 20 Aug 11, 2005 08:22 PM
Where to buy True RC lipos? 717 Batteries and Chargers 4 Jun 04, 2005 02:06 PM
Poly-Quest Lipos andyg Batteries and Chargers 5 May 23, 2005 06:46 PM
Poly-Quest Lipos? lsnover Batteries and Chargers 9 Dec 31, 2004 12:16 PM
