Apr 02, 2006, 06:16 PM
Evil Plane Doer
jskrebs's Avatar
12 gram outrunner from GB components 5.375OZ of thrust
Here is a motor I made up to power a mini plane I am working on
GB 20mm cut down stator and can
21 turns of 27G wire WYE termination
GBV bearing and shaft
CF mounting tube
12 1x4x5 N35 magnets
Might try to shave some more weight with a CF shaft, driling the can, and plastic bearings
Spinning a Graupner Cam Slim 5x5 prop on 2S it generated 5 3/8 OZ of thrust
Pictures show it next to a 22.7mm motor I make for MAE
Apr 02, 2006, 09:54 PM
If you would make these available for sale, it would be sooooo cool.....
Apr 02, 2006, 10:03 PM
gone fishing
Apr 03, 2006, 06:00 AM
Evil Plane Doer
jskrebs's Avatar
I probably will. Built as shown it will only cost a bit more than the 22.7 motors. There are extra steps such as cutting down the can, splitting the stator, and fitting the CF tube/bearing/stator together that take longer than the larger motor. Could also offer KIts with a tutorial for DIYers
How about 6 magnets and double the amount of turns?
Good idea, but may have to go to thinner wire and leave the can a bit taller as the windings are just about clearing it now.
Apr 03, 2006, 06:55 AM
in pursuit of low wing loading
Gordon Johnson's Avatar
Nice. What is the amp draw to go with that thrust?
Gordon
Apr 03, 2006, 07:32 AM
Evil Plane Doer
jskrebs's Avatar
I did not write it down, but I recall it was high 2's low 3's I want to be able to run on 250 2S packs. It's the 1st one I made up and I guessed at the winds. I will refine from here.
I am out of town for a few and will update upon my return
Apr 03, 2006, 07:37 AM
Is that the E-Tec 250's you are referring to? My guess is you will either need to go to a much milder wind or go with a larger and higher discharge capable cell. ET-250's really can't be used with amp draws much higher than 1.75A or the flight times get pretty short. You can find my ET-250 tests here.
Gordon
Apr 06, 2006, 05:58 PM
Evil Plane Doer
jskrebs's Avatar
Thanks Gordon,
Perhaps some 340's then?
May 17, 2006, 10:22 AM
Propjob81's Avatar
Did you ever refine this motor? There are some 300mah with 20c disharge that are farely light weight. Around 20g for a 2s pack with wire.
May 17, 2006, 06:29 PM
Evil Plane Doer
jskrebs's Avatar
I have installed it in my Stevens Aero Lil Squirt. I used a 3x3 prop on the same motor and am using the 250 battery for now. I can run the motor with the 5x5 on a 4502S Etec, but it has way to much power for the airframe. I'll post pics and perhaps a backyard video soon.
I also plan to make up 5 to 10 units over the weekend and try some different setups.
May 17, 2006, 07:46 PM
Evil Plane Doer
jskrebs's Avatar
3x3 does not cut it. It was only drawing 1/2 to 3/4 amp.
I porpoised and broke it and have nothing between it and the 5x5. I'll put on the 5x5 and the 450 pack and give it a whirl tomorrow. Should be able to hover and get a torque roll or 2 )
May 17, 2006, 09:47 PM
Matt D.'s Avatar
Where did you get that cool 3X3 prop and spinner? I didn't see it on Hobby Lobby's website.
Matt
May 18, 2006, 04:17 AM
Evil Plane Doer
jskrebs's Avatar
I got it at hobby lobby. It's in the non folding section. both are made by Graupner. I hae to drill out the spinner for the 3mm shaft on my lather. It comes 2.3mm.
New Product 12-gram BL Outrunner for F3P! 3d_Crazy Indoor Pattern/F3P 241 May 02, 2007 10:08 AM
Discussion Home for an AXI 2826/12 on 1.5 to 1 thrust ratio? BytheBookie3 Glow to Electric Conversions 1 Dec 31, 2005 11:56 AM
CD-ROM Brushless from GB: Part 5 t-turley Electric Power Systems 795 Dec 01, 2004 08:54 PM
How much thrust from a GB kit? JIMA Electric Power Systems 16 Jun 08, 2004 09:13 PM
6th channel from FMA Extereme-5 pullin-gs Electric Power Systems 3 Oct 26, 2001 01:36 PM
