Mar 30, 2006, 01:44 PM
BP-12 Delta use in a pusher jet
Anyone fly this motor in a pusher jet? If so what prop, plane AUW? How do you like it?
Mar 30, 2006, 04:02 PM
dottney's Avatar
I've got one in a T38 Parkjet using a 3S Maxamp 1500 or Vampower 1700 pack with a GWS EP 8x6 prop. All up weight is 16oz. Flight performance is stellar. Very fast and smooth.
A buddy is flying is OV10 Bronco on 2 BP12's (Towerpro, or whatever youwant to call them today). This plane comes in at something like 34oz or a bit more, I can't remember. He's using 3s packs and I think 9x4 or 9x6 props.
Hope this helps
Mar 30, 2006, 11:26 PM
Hi Dave, I maidened my F-5 today w/ BP-21 & GWS 8x3.8" prop & it was not very stellar to say the least. Do you think it would fly better w/ the BP-12?
Best regards,
Dale
Mar 31, 2006, 09:37 AM
dottney's Avatar
Try a GWS 8x4 HD prop with the 21 motor first. I'm assuming you're using a 3S lipo pack capable of delivering up to 15A.
Dave
Apr 01, 2006, 10:09 AM
Thanks Dave, today I'll give it another try. 3S 1250mah 8C. My Watts Up meter gave the following #'s:
GWS 8x3.8, 11.56v, 67w, 5.6a
GWS 8x6, 10.88v, 74w, 6.7a
Apr 01, 2006, 04:08 PM
dottney's Avatar
Dale,
I think your battery pack might not be up to snuff. The 8x4 on the 21 motor with a 3S pack should pull about 13-14A. Your 1250 8C pack can't safely put out that much amperage.
Dave
Question Best tower pro motor / prop for speed in a pusher jet pval3 Pusher Prop Jet Models 12 Dec 07, 2007 02:48 PM
Discussion Rewind BP-21 for use in edf? ronmeister Electric Motor Design and Construction 6 Nov 27, 2006 05:31 PM
Discussion How to use in pusher configuration - shaft too small? Nethole Power Systems 1 Oct 24, 2006 07:54 AM
For Sale BP-12 Delta/Triangle Brushless Motor and GEN 2 15A Speed Controller Combo Lt.Smash Aircraft - Electric - Power Systems (FS/W) 0 Mar 07, 2006 09:46 PM
For Sale BP-12 Delta/Triangle Outrunner Brushless Motor and 15A Speed Controller Combos Lt.Smash Aircraft - Electric - Power Systems (FS/W) 0 Mar 03, 2006 06:14 PM
