Jan 27, 2014, 09:23 AM
"Some do, some don't"
old_coastie's Avatar
Oh Heck Yeah!!!!
+1 +1 +1......
Video looks great just the way it is... (played full screen).....
I was extremely impressed with the flight characteristics, You were flying this bird exactly the way I like to fly my planes (just that you are better at it than I am)...
Thank you so much for sharing...
Ok this could be next up on build table, have a couple of UM bricks that I could use for this...
Want to have this ready for EFEST (I Hope)
Anyway, any special insights on the build???
Is this a straight 50% reduction of the plans?????
Solid work.....
Mark R.
Jan 27, 2014, 09:53 AM
Flying...Pushing Air Down
sr71fan's Avatar
Mark,
Glad you like it. I use "Tile Print" to scale my models up or down. I just tell it what span I want. Don't really know what the plans call for. If the span is 24 inches, then, yes, it is 50%.
One thing you might keep in mind... keep everything as far forward as you can so you won't have to add nose weight like I did.
Gary
Jan 27, 2014, 11:45 AM
Gary,
Keeping everything forward applies to all of the Bipie's, I HATE DEAD WEIGHT.... Just bugs the heck out of me....
When I read thru the thread that was a common observation, to counteract I added 10 mm to nose ahead of LE wing (didn't want to mess up the "desired" CG), that and I didn't decide on servo location until after I had the airframe dry fitted, then started taping on servos and electronics. An extra step or two that took some time but was worth it I think, no dead weight required (although my aileron servos are 9 gm versions as opposed to 5 gr because I needed that extra weight up forward...)
Thanks for replying...
Mark R.
Jan 28, 2014, 02:27 AM
sr71fan's Avatar
Aspect Ratio Fixed (on the video)
Mark,
I thought I had the brick and battery far enough forward. I'll lengthen the nose on the next one. Thanks!
Correct aspect ratio on the same video...
Gary
Micro Bipie Indoors Correct A/R (2 min 19 sec)
Jan 28, 2014, 08:18 AM
egicar's Avatar
Originally Posted by sr71fan View Post
Mark,
I scaled down the plans to 12 inches span, used 3mm Cellfoam from Hobby Lobby (the craft store), and put Vapor gear on it. 3-channel with undercamber, dihedral on top wing, and no ailerons. I had to add some noseweight; it's now at 23.8 grams, and I'm using a 140 battery. I was surprised the Vapor powerplant flies it so well.
Gary
Great idea, Gary!!!
The full scale one was my first DIY plane
Now I'm working on a scaled down one (about 300mm w.s.) as your.
Mine will weigh about 45g, because I'll use:
- a Orange R415 micro receiver, 2g
- 2 x HK 1.7g linear servo (rudder and elevator)
- a HK-5320 Ultra-Micro Digital Servo 1.7g for 4 ailerons
- a 7A ESC, 7g
- a micro brushless motor 3000KV, 3g
- LiPo Nanotech 2S 120mAh, 8,5g
ASAP some photos.
Ciao,
Egidio
Jan 28, 2014, 07:28 PM
ggrimley's Avatar
Egidio... Where did you find a 3 gram motor??? Do you need a magnifying glass to see it???
Jan 29, 2014, 04:15 AM
egicar's Avatar
It's really a little motor, but I can see it without a magnifying glass
AP-03
It's a 7000KV, not a 3000KV as I wrote
Ciao,
Egidio
Jan 30, 2014, 02:18 AM
egicar's Avatar
I had to change my project about the motor: too small and too KV.
I mounted a Turnigy 2000KV.
Here are some pics
Description: Name: ImageUploadedByTapatalk1391066230.141189.jpg
Description: Name: ImageUploadedByTapatalk1391066250.177194.jpg
Description: Name: ImageUploadedByTapatalk1391066268.460633.jpg
Description:
Jan 30, 2014, 02:43 AM
egicar's Avatar
"Bipie" - Profile depron biplane cartoon style
I have to connect the AIL servo with ailerons and the little baby will fly 😊
Jan 30, 2014, 08:54 AM
First of All..... Whoooo Hooooo!!! Nice Job....
Beautiful Plane, really, a perfect example of keep it simple....
When you get time would really like some close up shots of well, just about everything...
I eagerly await your flight report... Best of Luck....
Mark R.
old_coastie
Depron Biplane kestrel2003 Foamies (Kits) 8 Oct 27, 2004 06:32 PM
Looking for small fast profile depron plane Mac8 Foamies (Kits) 3 Oct 12, 2004 07:53 AM
Depron Biplane - My first scratch build pjsmith The Builders Workshop 0 Jun 28, 2004 05:30 AM
Question Whats the cleanest way to mount a B20 to a Profile depron fuselage? JoshFlies3d Foamies (Kits) 8 Nov 01, 2003 07:57 AM
Video of Matt Fritz Depron Biplane... kepople Foamies (Kits) 11 Oct 17, 2003 09:41 AM
