Mar 19, 2006, 08:55 AM
PiperLance's Avatar
Blade CP Owners Thread - Part II
Wow - over 3,000 posts and 160,000 views in the original thread in just 8 months. That is great!
Tech support sent me a polite pm suggesting to close the original and start a "Part II" thread. The original is so large that it is slowing the server.
So here goes with Part II. Please put all new posts here.
If you want to search any of the 220 pages of Part I discussions, which went from 7/18/05 to today, 3/19/06, use the link below. There is a ton of great information there. Sticky Collective fix, beginner instructions, upgrade tips, etc.
PL
Mar 19, 2006, 09:15 AM
Plastic Buddha
aftica's Avatar
Mar 19, 2006, 11:34 AM
BCP gear and pinion mesh
I have read about the importance of main gear to pinion mesh, but, how are you to set this up right when the gear runs concentric to the main shaft? Viewing from the bottom, powered up, the main gear oscillates a good mm or more from true center. Installed a new shaft and gear and it did the same thing.
Mar 19, 2006, 12:02 PM
Plastic Buddha
aftica's Avatar
Mar 19, 2006, 12:18 PM
Formerly p51flyer
ok so on my 4 in 1 i have turned the transmitter on, then pluged in the battery.... will it not turn green, if I don't have blades on the heli?
Mar 19, 2006, 12:22 PM
P51
Is your throttle and trim all the way down and Idle up switch pushed toward the back of the Tx...Pilot
Mar 19, 2006, 01:34 PM
Aftica, thanks for the gear info...please, one more question. Are those factory settings for sea level density altitude? A few thousand feet can really make quite a difference in such a small machine.
Mar 19, 2006, 02:25 PM
Spongebob's Avatar
Wow, 3000 posts. Nice....
Good to hear the BCP is still going strong. I gotta get flying again! (I've been very busy lately, but today is an off-day, if you know what I mean. )
Sponge.
Mar 19, 2006, 02:57 PM
Good to hear about the part 2
It was getting hard to search through for the info i was looking for,
My first question about the gear mesh was just answered thanks guys,
My second is, how far can i go with the stock battery, can i put symetrical blades on it? and a motor/pinion upgrade? or am i stuck with what i have until i get LiPos
thanks Chuck
Mar 19, 2006, 03:07 PM
Plastic Buddha
aftica's Avatar
Mar 19, 2006, 03:25 PM
thanks, I sort of figured that, Lipos kind of scare me, i dont want to burn anyhting,
but i guess in time it will be the way to go
One more question, How much wear or "play" is acceptable on the linkages on the swash plate, They seem kind of slopy but maybe im just too pikcy
thanks
Mar 19, 2006, 03:33 PM
Plastic Buddha
aftica's Avatar
Mar 19, 2006, 03:40 PM
I keep on going to the hobby shop hoping they have a never flwon before demo model to see how much more sloppy mine is, but they dont,
I noticed the replacement tail support has a "fin" on it, is it better or worse or no effect.
It is a fun machine, i have over 100 batteries through it all in the hover with a little forward movement, too bad my apartment wasnt bigger, all of this on the original motor's i guess luck is on my side
Mar 19, 2006, 03:53 PM
Plastic Buddha
aftica's Avatar
Mar 19, 2006, 04:12 PM
b7gwap's Avatar
My BCP has the symm woodies, the stock 10 tooth pinion, and when I fly the stock NiMh, it hovers for about three minutes. Get a lipo. Question- with the 11 toother anda 2S batt, can you fly symmetricals?
Cheers
Austin
Build Log Mountain Models ETana build thread - Part II SchiessCo 3D Flying 640 Sep 12, 2015 09:33 PM
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 09:28 PM
New! Blade! ALL EPP Shocker! Part II Ron Williams 3D Flying 107 Oct 04, 2008 02:38 AM
Discussion LensRC Users Thread Part II Michael Heer Parkflyers 401 Oct 13, 2007 11:52 PM
Discussion Blade CP Owners Thread PiperLance Micro Helis 3281 Mar 19, 2006 09:01 AM
