Mar 16, 2006, 09:11 AM
fredok's Avatar
Build Log
Skyraider Speed 400 sized
After looking at all the magic work of adrian, I decided to get into the 400's stuff.My first try will be a A1 Skyraider.
Built as began yesterday, here is a shot of the basic Frame of the fuse..
To be continued
Fred
Mar 16, 2006, 09:50 AM
thomanie's Avatar
Cool!
What's the details on size, power etc? Own plan?
Thomas
Mar 16, 2006, 10:29 AM
fredok's Avatar
Hi thomas,
Power is at least speed 400, and more probably a small brushless like typhoon 6.
It's planned to make she fly on a 3S lipo like 1500-1800mAh..
Span is 950mm, yes it's a own design. I hope that tonite I gonna make more work on the fuselage, before starting the wings. every thing is not already drawn and/or decided.
If she works well, I hope to make a short kit !
She will be in a french color scheme.
Fred
Mar 16, 2006, 12:45 PM
Good On Ya, Fred!
Go for the Typhoon and a 1200 Lipo. Give your design what it looks like to me so far to deserve
I'll be watching.....
Ade
Mar 16, 2006, 03:03 PM
fredok's Avatar
HI Ade.
I' was also planning while going back home in the subway to use a axi 2812/34 with a nice varioprop 4 blades prop. I Have both, so It might be a solution.
Fred
Mar 17, 2006, 04:57 AM
fredok's Avatar
More, but small progress
Hi alls,
Yesterday I did cut some more parts.
I'm planning to finish the fuse this week-end
Mar 17, 2006, 01:57 PM
Grain Direction...
C'est importante!
Good to see you also keep the hinge lines to scale, it really counts in the presentation.
Think "Centre of Gravity" and final weight all the way along the project, and design in the essential washout. You will have fun! ...and win
Formidable!
Ade
Mar 17, 2006, 02:52 PM
thomanie's Avatar
Having a few shortnosed fighters under my belt I have to fully agree with Mr.Brittons statements!
A typhoon 6 is mighty light, as is the lipos, and with the (quite) short nose you definately need to think "light tail" and "CG" all through the build!
Looking good!
Thomas
Mar 17, 2006, 02:53 PM
No Guts No Glory
kestrel2003's Avatar
At last! I look forward to the result...
Good luck! I look forward to the plane! A very under modelled plane, for a plane that in real life looks so cool
Will you be going for a French Air force coloring?
Mar 17, 2006, 03:14 PM
fredok's Avatar
Ade,
You think I've made a mistake in the grain direction ?
I'm always a bit in trouble for the formers...
I hope that this design will go well...
Thanks for the comments.
I've start the fuse planking but no pics as now.
Fred
Mar 17, 2006, 03:16 PM
fredok's Avatar
That a problem with short nosed planes, why don't we have small radial engines ;-) !!!
Yes she will wear a french air force scheme. bare metal, and anti glare panels.
Fred
Mar 18, 2006, 01:46 AM
All Good...
Originally Posted by fredok
Ade,
Fred
No! No! - You've got it right enough
With weakish formers you can always tack on some scrap strip and chop it away later after a bit of planking begins to take hold. In fact, the more meat you can dig out of the rear fuselage without compromising strength, the better!
Ade
Mar 24, 2006, 12:26 PM
Shaping Up!
Developing bien!
Are you hingeing the elevator/tailplane by laminating them from (say) 2.5mm and 1.5mm balsa, and trapping the hinges in between?
Ade
Mar 24, 2006, 02:51 PM
fredok's Avatar
HI Adrian
For hingeing I have planed to use pin point Hinges. The tailplane and rudder are only 3mm thick.
at this stage The fuse weight 100grams ( a little less than 4oz ;-)). I think it's a bit heavy ?
I will pay more attention for the wings.
Fred
Is there a speed 400 sized Lockheed Sirius Immelmann Scale Kit/Scratch Built 8 Jul 09, 2004 02:42 PM
What is the Hottest Brushless setup for a speed 400 sized sailplane. soholingo Electric Sailplanes 10 Dec 14, 2002 11:53 PM
What is the Hottest Brushless setup for a speed 400 sized sailplane. soholingo Power Systems 2 Dec 13, 2002 12:22 PM
suggestions for speed 400 sized plans? Bob Chiang Electric Sailplanes 5 Dec 11, 2002 09:52 PM
Speed 400 sized Pond Baby? JBowling Parkflyers 0 Jan 08, 2002 11:47 AM
