Mar 07, 2006, 02:47 AM
Aiptek Pocket Cam X...anybody tried one? Thoughts?
The Aiptek Pocket Cam X can record 320 x 240 video with sound at 24 fps.
SD cards of up to 512 meg are supported.
It seems like this would be a good AP video cam and a lot cheaper than a Sony S600, or S40 (if I could find a good one).
The frame rate is a lot better on the Pocket Cam X than on the Pen Cam SD 1.3.
What do you think?
Mar 26, 2006, 12:13 AM
CARL T
Carl T's Avatar
OK, Where can I get one of these and what do they cost, Please.
What is their site add.?
Carl
Mar 26, 2006, 12:22 AM
go to: 2fidelity.com
this is the promotion division of Aiptek
Mar 26, 2006, 03:40 AM
lvspark's Avatar
Pocketcam x works pretty good.. Used to be my primary camera.
Pic from pocketcam x http://www.rsnw.com/AP11.htm
Mar 26, 2006, 10:52 AM
Am I registered?
Randy Due's Avatar
Yeah, the X is a good inexpensive cmos type camera. I have one. I always thought it did a good job on stills and a fairly good job on video. You'll get the wiggles if there's too much vibration, so motor off is best.
Randy
Mar 29, 2006, 01:07 AM
v3611504's Avatar
Randy
I agree...the Pocketcam X was my 1st AP camera I started out with 2 years ago. Photos came out good for a Cmos camera. If you take photos or video with the motor on you tend to get wavy lines as cmos shows more vibration than CCD. After I got more hooked I moved up to a better CCD camera. One good thing with the Pocketcam X is that you can power the camera off of your receiver and save some weight without the 2 AAA installed
Mar 29, 2006, 12:43 PM
Am I registered?
Randy Due's Avatar
Yes, it's very light weight that way. So is the Pencam SD. Aiptek makes some good starter cameras for AP. I've tried 4 different Aipteks. The newest being the MPVR. I only use it for capturing video from a downlink though. Does a great job too....and a lot smaller than a vcr! I pretty much use a better ccd camera for stills now also, but at the expense of a lot more weight. This hobby is very addictive.....
Randy
Mar 29, 2006, 03:41 PM
bobbygee's Avatar
How do you set it up to power it from the receiver?
I'm about to order one and would like to know how to do that.
Thanks!
BobbyG
Mar 29, 2006, 06:18 PM
Rogerdoger's Avatar
........ "you can power the camera off of your receiver and save some weight without the 2 AAA installed."
I am interested in how this is done. I have a Pocket X and like the pics that it produces. The way I have used it was to put the batteries in the cam and trigger the cam with a servo. That added a lot of weight. I like to fly with the 1.3 SD the best. It has lower weight and is not as large.
Roger
Mar 29, 2006, 06:59 PM
v3611504's Avatar
To power the camera check out this post....it worked for my pocketcam X you can just solder some wire to the battery leads on the camera and run them to a spare RX + and for power
https://www.rcgroups.com/forums/showthread.php?t=298019
Mar 29, 2006, 08:23 PM
Am I registered?
Randy Due's Avatar
If I remember correctly, I used a combination of these:
http://www.designsoft.com.au/ahome/rc/jazz/jazz.html
How to modify an old servo for switch:
https://www.rcgroups.com/forums/show...two+warranties
Randy
Mar 30, 2006, 01:05 PM
Design > Build > Fly
Qrome's Avatar
I have been using the Pocketcam X for over a year. Both video and photos can be viewed at http://www.stickflyers.com
Discussion anybody tried one little fan in front, one mid fan in back? lostrider Electric Ducted Fan Jet Talk 27 Jun 16, 2006 04:34 PM
Aiptek Pocket Cam X I need a Switch!! Rogerdoger Aerial Photography 7 May 10, 2005 08:37 PM
Project X: Anybody Have one? Orion_V Electric Heli Talk 6 Dec 30, 2004 08:46 PM
pocket cam x problem Wingo 1 Aerial Photography 15 Jul 18, 2004 04:45 AM
E-starter and Pocket Cam X isaacslaw Aerial Photography 9 Mar 21, 2004 12:43 AM
